JD 540M Loader with Global Carrier Questions
   / JD 540M Loader with Global Carrier Questions #21
How many chicken houses do you have? It's nice to have compatible tractors and loaders. Now with the global carriers it makes everything a carbon copy.
I’ve got 153k Chickens total in 6 houses.
Does anybody know if H260 & H340 carriers will interchange ?
   / JD 540M Loader with Global Carrier Questions #24
I can give you the measurements tomorrow. For the bolt diameter, I may have to get a close guess.
I took a skid steer carrier off a 540M (Same as H260) I bought & a buddy is wanting it for his H340.
I think it’ll fit
   / JD 540M Loader with Global Carrier Questions #26
The inside width between the loader arm is 38", the outside is 44 1/2", the bolt distance is 10 1/4" and the bolt diameter is 1 3/4".
I'm usually a metric guy and tried to get the imperial reading as good as possible.
Bolt or Pin diameter ?
   / JD 540M Loader with Global Carrier Questions #28
Pin diameter.
   / JD 540M Loader with Global Carrier Questions #29
I see, I posted " bolt diameter". It should say "pin". I didn't take the snap ring out, but I assume the tiny edge outside the ring is the real diameter of the bore already.
My pins are about 35mm or 1-3/8” so it probably won’t fit the H340
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2015 Ford F-350 Knapheide Service Truck (A55852)
2015 Ford F-350...
Case 460 (A53317)
Case 460 (A53317)
2017 Volkswagen Passat Sedan (A55853)
2017 Volkswagen...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
2016 Dodge Caravan SXT Van (A55853)
2016 Dodge Caravan...
