JD 540M Loader with Global Carrier Questions
   / JD 540M Loader with Global Carrier Questions #21
How many chicken houses do you have? It's nice to have compatible tractors and loaders. Now with the global carriers it makes everything a carbon copy.
I’ve got 153k Chickens total in 6 houses.
Does anybody know if H260 & H340 carriers will interchange ?
   / JD 540M Loader with Global Carrier Questions #24
I can give you the measurements tomorrow. For the bolt diameter, I may have to get a close guess.
I took a skid steer carrier off a 540M (Same as H260) I bought & a buddy is wanting it for his H340.
I think it’ll fit
   / JD 540M Loader with Global Carrier Questions #26
The inside width between the loader arm is 38", the outside is 44 1/2", the bolt distance is 10 1/4" and the bolt diameter is 1 3/4".
I'm usually a metric guy and tried to get the imperial reading as good as possible.
Bolt or Pin diameter ?
   / JD 540M Loader with Global Carrier Questions #28
Pin diameter.
   / JD 540M Loader with Global Carrier Questions #29
I see, I posted " bolt diameter". It should say "pin". I didn't take the snap ring out, but I assume the tiny edge outside the ring is the real diameter of the bore already.
My pins are about 35mm or 1-3/8” so it probably won’t fit the H340
excavator trenching bucket- one bucket per lot (A56436)
excavator...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
2014 Ford F-350 Pickup Truck (A55973)
2014 Ford F-350...
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2018 MQ POWER...
