Stripped transmission drain plug - Ford 4100
   / Stripped transmission drain plug - Ford 4100 #41
That's pretty ugly. I would take an air chisel to it.
   / Stripped transmission drain plug - Ford 4100 #42
The plug looks proud of the surface. If you can get good purchase with a chisel, it might be worth drilling out the center as large as you dare and caving in the plug from the side. I don't expect that thing will come out in one piece.
   / Stripped transmission drain plug - Ford 4100 #43
Looking at that picture, I still think you have some corrosion from dissimilar metals going on. I still think a bit of heat will help to break that loose. It does not need to glow red just get it warm. If you have access to an air chisel, use it. The impacts from it or from a hammer and chisel will do wonders in breaking it loose. Your current plug is already destroyed so do worries there. Go from the outside edge and try to follow the turn of plug as if unscrewing it. If you drill out the center, you can crush he plug to the center as you chisel and save the pan threads. I would try to stay 1/4” away from any edge if possible. That allows for good threads in the pan to remain and then a hot plug (again it should not need to glow red) will crush to center fairly easy.
   / Stripped transmission drain plug - Ford 4100 #44
I bought an 80's Ford 4100 diesel a couple of years ago and I need to change the transmission fluid. However the plug is stripped, so I can't get it out. It's the type with an inverted 1/2 inch square which was almost completely rounded. I couldn't get any bite with my 1/2 breaker bar so I ordered some extractors. The plug seems to be soft metal as the extractors seem to get a little bit of a bite and then just start eating away material.
I'm not sure what else to try, I was going to try and collapse in the sides so that the threads would be loose but it sits almost flush with the transmission housing so I can't really get much forse from the outside.
Any suggestions?
Seal it up with epoxy and buy an oil extractor. I no longer use drain plugs on any of our engines. Haven't for about 6 or 8 years.
Ralph
   / Stripped transmission drain plug - Ford 4100 #45
Take it to a dealer and let them do it. You're doing things for the first time here and there's a learning curve to many of these suggestions. You could wind up making things much worse. Sometimes, paying to have things done makes life much easier.
If you're too far from a dealer there usually are tractor repair guys around that will come out to your place. I've called on help a couple times and I think it saved me.
   / Stripped transmission drain plug - Ford 4100 #46
I warm the area around the plug with a propane torch the spray the centre of the plug with plumbers pipe freezer, rapid contraction of the plug usually gets it undone
Ralph
So I got the extractor yesterday. I started the tractor yesterday and drove it around for about 5 minutes then let it sit and idle for another 20 minutes to warm the transmission fluid, however the fluid was still cool to the touch. I was thinking with the clutch out in neutral there would be enough spinning and friction going on but I guess not. I'm thinking it won't warm up without some kind of load, is that your experience? Maybe if I pick up a large bale and drive around for a bit.
I'm not a dealer type of person, I've been doing all my and family car repairs for 30+ years. In that time I've only had a couple of occasions where I couldn't figure out the problem and took it to a shop. One of those times they coudn't figure it out either after a couple of hours diagnosis, then when it died on my way home from the shop I figured it out. Being stuck on the side of the interstate gives you new motivation to check things you hadn't checked before. If I don't do things for a first time then it's always the first time. First times can be frustrating but usually the same thing is pretty easy by the second or third time.
   / Stripped transmission drain plug - Ford 4100 #49
Well not really. Sadly, those of that that dabble in so much stuff, can't possibly remember everything. Maybe just some basics, applicable to a broad range of problems.
I like to think that a clueless person (Me) that cares, and has the luxury of time, is always a better bet than the clueless person at the dealer that is under time pressure and in all probabilty doesn't really care.
   / Stripped transmission drain plug - Ford 4100 #50
Good way to put it and it's how I learned. Most things I did wrong the first time or two but gradually figured it out. With you're positive attitude, you'll be OK.
2010 CATERPILLAR 140M MOTOR GRADER (A51246)
2010 CATERPILLAR...
UNUSED FUTURE XJ3T 3TON 30" HYD THUMB CLAMP (A51248)
UNUSED FUTURE XJ3T...
TEST YOUR BID BUTTON! (A51248)
TEST YOUR BID...
2006 Nissan Xterra 4x4 SUV (A51694)
2006 Nissan Xterra...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
