bad fuel on the bx23.
   / bad fuel on the bx23. #11
Rather interesting...
I would change your fuel filters like now, before adding fresh fuel.
   / bad fuel on the bx23. #12
Might as well replace that burned up fuel pump while you’re at it.
   / bad fuel on the bx23. #14
I surely don't recommend you treat your Kubota BX23 to a tank full of 5 year old diesel again. Don't completely run the Kerosene out of the entire fuel system. Please put in new diesel ASAP to get that wonderful BX running properly again.
Why didn't you leave it outside?
Is it ok to keep it outside ?
I kept my JD950 outside and it didn't care at all.
It was more rigged than my kubota, I think.
I need another cold day to tell if the fresh fuel is working.
I don't know how old the old diesel fuel was.
I only put it in to move the tractor around and get it to be serviced.
There was too much to fix for me to want to do.
   / bad fuel on the bx23. #16
It's ok to keep it outside but smoking out the barn why? Fuel will last years if no water is in it.. But if you keep the tractor inside it will last longer and have less problems and have a better resale value..:2cents:
   / bad fuel on the bx23. #17
^^ This is has got to be the weirdest thread I've seen in a while.
I have a feeling the OP has bad English and accidentally switched up the words.
If not, then I'm like, huhhhh?!!?!
   / bad fuel on the bx23. #18
LOL...:)
   / bad fuel on the bx23. #19
His BX has over 1300 hours on it, thats pretty good use of it. These can be kept outside but it would be good if you installed a hot plug and used Diesel treatment to keep the fuel from gelling up.
   / bad fuel on the bx23. #20
I built my first house in his town, he is not indicative of the local population.
2014 Ford Fusion SE Sedan (A50324)
2014 Ford Fusion...
2007 Toyota Camry Sedan (A50324)
2007 Toyota Camry...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2022 Wacker Neuson SM100 Mini Skid Steer (A52748)
2022 Wacker Neuson...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
