bad fuel on the bx23.
   / bad fuel on the bx23. #11
Rather interesting...
I would change your fuel filters like now, before adding fresh fuel.
   / bad fuel on the bx23. #12
Might as well replace that burned up fuel pump while you’re at it.
   / bad fuel on the bx23. #14
I surely don't recommend you treat your Kubota BX23 to a tank full of 5 year old diesel again. Don't completely run the Kerosene out of the entire fuel system. Please put in new diesel ASAP to get that wonderful BX running properly again.
Why didn't you leave it outside?
Is it ok to keep it outside ?
I kept my JD950 outside and it didn't care at all.
It was more rigged than my kubota, I think.
I need another cold day to tell if the fresh fuel is working.
I don't know how old the old diesel fuel was.
I only put it in to move the tractor around and get it to be serviced.
There was too much to fix for me to want to do.
   / bad fuel on the bx23. #16
It's ok to keep it outside but smoking out the barn why? Fuel will last years if no water is in it.. But if you keep the tractor inside it will last longer and have less problems and have a better resale value..:2cents:
   / bad fuel on the bx23. #17
^^ This is has got to be the weirdest thread I've seen in a while.
I have a feeling the OP has bad English and accidentally switched up the words.
If not, then I'm like, huhhhh?!!?!
   / bad fuel on the bx23. #18
LOL...:)
   / bad fuel on the bx23. #19
His BX has over 1300 hours on it, thats pretty good use of it. These can be kept outside but it would be good if you installed a hot plug and used Diesel treatment to keep the fuel from gelling up.
   / bad fuel on the bx23. #20
I built my first house in his town, he is not indicative of the local population.
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
2012 DIAMOND CARGO FOOD TRAILER (A52472)
2012 DIAMOND CARGO...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2016 Ford F-450...
2018 Ford F-150 Pickup Truck (A51692)
2018 Ford F-150...
2017 Jaguar F-Pace AWD SUV (A50324)
2017 Jaguar F-Pace...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
