Injector cleaner
   / Injector cleaner #1
greif
kaukauna,wi
Yanmar sx3100
Does anyone run desiel injector cleaner through once in a while as preventative and which brand do you like
   / Injector cleaner #2
At a risk of taking a lot of flak from some members on here, I always do and have been adding to my fuel for a long time. Again, at a risk of taking flak, I use Sthil two stroke oil. Why the Stihl two stroke oil, well I think the oil is made to add to fuel to lubricate, and as I use it for my saws and buy it by the gallon at a good price, so there always some in the shed. Occasionally I put some in the fuel of my car, a 4 year old Mercedes, and I also add a small amount to the petrol [Gas] of my mower. My thinking is that the fuels today have had a lot of the additives removed for pollution reasons, and are too `dry`. I never seem to have any problems with my engines even though I been doing it for years. Our cars have to be tested every year, and mine always come back and is always well within the limits. It might just be me, but I think you can hear when the oil gets to the engine as it seems to run sweeter. I did have an old diesel fishing boat, and that old engine was as good when I sold it as it was when I bought it after many hours of hard work.
   / Injector cleaner #3
I've cured several "sick" diesels with a quart of ATF in the fuel tank.
I wouldn't think you should need anything for a newer engine in good shape.
Winter additives are needed,of course.
Good Luck!
   / Injector cleaner #4
When our 240D Benz was stored for 4 years, the diesel turned brown. Used some Chevron diesel additive that was highly recommended at that time.
Have heard about the ATF thing, too. ATF is just diesel that got diverted to ATF pool for lube oil processing but has some additives that are apparently helpful.
I'd read the label on the SeaFoam. Might be good. Have used it for years to solve carb problems and works great. Have read herein where some have used in diesel.
Ralph
   / Injector cleaner
I talked to a coworker with a ram truck with a Cummins and he uses power service brand injectors cleaner twice a year as this is what Cummins recommends
   / Injector cleaner #7
I am just not a fan of additives, and I would especially stay away from ATF. ATF has a ton of additives and detergents. MAYBE on an old indirect injection engine it might help a stuck injector. On a newer high pressure common rail no way. Unless your engine is running bad, why add anything? I do add an additive to help with gelling.
   / Injector cleaner #8
I use Power Service silver in the summer, and PS white for winter.
They list both as having lubricating qualities, but only the silver lists injector cleaner.
   / Injector cleaner #9
...and I'm not a fan of Dodge diesel trucks, so what? ATF (Dexron-Mercon) works fine as a diesel additive and cleans injector pintles, been using it for decades.
   / Injector cleaner #10
The problem is people post they have been using some additive for years, and there Tractor, truck, car, whatever runs great with it. The question is would the results be the same if they haven’t been using the additive. I have actually done research on this subject in the past and haven’t come to my opinion lightly. That said it is an opinion, and I drive a Ford truck, not a Dodge.
   / Injector cleaner #11
I never used any additive during the 7 years with the VW TDI. They don't recommend any.
Very seldom did on the 240D: that once after being stored and once with some ATF. Nothing else in 25 years.
   / Injector cleaner #12
I drive Ms. Daisy................:)
   / Injector cleaner #13
I run,have run for as long as I can remember, Power Services grey in my 5 diesels, per bottle recommendations continuously. I recently started adding a quart of ATF/100 gallons for pump/upper cyl lube due to ultra low sulphur diesel.
   / Injector cleaner #14
I think a lot of what you add or don’t add has a lot to do with the age of the machine. Newer stuff definitely is designed to run on the ultra low sulfur fuel. Older stuff not so much.
When I owned a diesel truck I did a lot of reading on the subject. My memory is a diesel truck mag did quite a bit of testing and the result was two stoke motor oil was the one that was the best. Ash less seemed to be important and I think the Wal Mart stuff was some of the best. Like I say this would be for older stuff not designed for low sulfur fuel.
   / Injector cleaner #15
In reality the only thing that sulfur in diesel does is lubricate the micro honed surfaces of the injector pump so with a common rail high pressure injection diesel there is really no mechanical pump, hence no precision wearing surfaces.
   / Injector cleaner #16
The injectors themselves are a wear item and are very sensitive to dirt. They also have the high pressure pump, such as a CP3, that are subject to failure. The newer stuff is just designed to run on modern fuels.
   / Injector cleaner #18
Everyone like to call any additive "Snake oil"
Well for 40 plus years I've adding snake oil to my vehicles and equipment and have never had an injector or engine problem. I even run a batter snake oil that kept my forklift battery alive for 15 plus years and at 5K a battery I'm glad I used the snake oil. My forklift company said they've never seen a battery last that long.
While everyone was having Toyota sludge problems with their Toyotas Vans in the 90 my van ran like a swiss watch. While people were having problems with their sprinter vans with injectors and EGR valves I went to 200k and never has an issue.
I've used the additive on my 30ft box delivery trucks, lawnmowers, compressors, pressure washers, etc, I put the stuff in the tranny, rear ends, front differentials, transfer cases anywhere oil goes I add my snake oil.
On a chevy van, my workers used they never checked the oil and it ran out of oil and knocking. The mechanic said the vehicle was junk. I filled it with oil my nuclear submarine additive and she ran for another 100K miles of abuse from my employees and ran great when I sold it to an employee who ran it for another 7 years.
I could not care less what people say about snake oil all I know is it has worked for me for decades and even yesterday My Kubota, Takeuchi excavator, and 2019 Ford F250 all got their dose of diesel additives and my special oil additives.
Could I have just been "lucky" on these dozens of vehicles or was it the snake oil? One will never know, but I do know my equipment runs better.
I just remembered the test I did 30 years ago before using the oil additive I use. I had an old 60-gallon compressor that I purchased used from a body shop. The compressor always got do hot you could smell it plus the powder coating was peeling off the head of the pump. It got so hot you could cook a can of soup on it.
I put in some of the oil additives and after that, the compressor ran so cool you could rest your hand on it, something you could never do before. Unscientific but it convinced me to use the stuff.
Don't ask what I use I'm not in the mood to debate the merits of the additive, it works for me and that's all I care about.
   / Injector cleaner #19
I remeber seeing a guy put transmission fluid in an old Chevy Suburban diesel. I asked why, he said he has 800K on the vehicle and he drops in a can of tranny fluid every three of four tanks. Who am I to argue he had the proof right there. That engines was one of the worst engines made and he had that many miles on it.
   / Injector cleaner #20
This is not about additives, but I had a mechanic years ago (80s or 90s) tell me to add some ATF to engine oil and run it before changing the oil. He said it's higher level detergents would help clean out the engine insides. He was a friend, not someone who worked on my cars.
KUBOTA SVL75-3 SKID STEER (A60429)
KUBOTA SVL75-3...
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
2010 Honda CR-V SUV (A59231)
2010 Honda CR-V...
(20) WOOD PALLETS (A60432)
(20) WOOD PALLETS...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
