LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 12,360
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Well I went looked a Bransons pdf spec sheet;
So apparently your range shifter is an in line shifter and not a h.
You say you are getting gear grinding on the range shifter,
The range shifter is not synchronized, so you should be stopped for that shift.
Your 4 speed gearbox is synchronized so it should shift nicely while rolling.
And then your shuttle is synchronized so it can be shifted while moving,
I would not recommend that as then you are using your clutch as a brake as well as a clutch.
If when trying to shift the four speed gearbox it feels spongy and does go nicely into gear,
it may be your clutch not releasing fully.
If when you are stopped in gear and trying to change the range selection you are getting gears to grind
to me that would be clutch adjustment.
Forcing the synchronized gears if the clutch is not fully releasing will wear the synchro's out.
