Top Five Frequently Used Construction Machines
   / Top Five Frequently Used Construction Machines #11
   / Top Five Frequently Used Construction Machines #12
   / Top Five Frequently Used Construction Machines #14
Awesome!!!
   / Top Five Frequently Used Construction Machines #17
   / Top Five Frequently Used Construction Machines #18
That JD grader you run is certainly a magnificent looking piece of machinery.
Are there pros to the Cat over the Deere, or pros to the Deere over the Cat?
   / Top Five Frequently Used Construction Machines #19
I've been casually observing constructions sites daily quite a bit over the past few years. Buildings around 5 stories, but not houses.
Tracked excavators are almost exclusively used to dig the holes. Several of different sizes at any given time. And at least one seems to stay on site until the job is done.
They almost always load directly into dump trucks. Sometimes there's a wheel loader on site, but more times than not, nope.
There's usually one dozer on site to grade the ramp into the hole, and to push dirt up a stockpile if they're keeping it on site.
Once the hole is dug, a crane of some type is usually on site for the duration. But after that, without a doubt, the most used piece of equipment is a telehandler. They do the majority of the work once the foundation is set until the exterior is done. Pretty much everything on the site gets moved with the telehandlers. Steel, lumber, bricks, appliances, HVAC equipment, drywall, windows, doors. Everything.
When everything is buttoned up and the exterior is done, a wheel loader and dozer reappear and either move the stockpile or take dirt from delivering dumptrucks.
As far as houses go, as others have mentioned, after an excavator digs the hole, it's a tracked loader, a small excavator, maybe a telehandler on a larger house, and that's about it.
   / Top Five Frequently Used Construction Machines #20
Oh, and lots of man-lifts. Those things are everywhere.
2007 INTERNATIONAL 9200I DAYCAB (A55745)
2007 INTERNATIONAL...
ASSORTED NYLON SLINGS (A54757)
ASSORTED NYLON...
2019 WACKER NEUSON LIGHT TOWER (INOPERABLE) (A55745)
2019 WACKER NEUSON...
2023 New Holland TS6.140 T4B MFWD Tractor w/ 830LA Loader (A53485)
2023 New Holland...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
