Would you buy a Kubota work truck?
   / Would you buy a Kubota work truck? #123
   / Would you buy a Kubota work truck? #124
   / Would you buy a Kubota work truck? #125
Some dump trucks have a gearbox on the pto with a shaft running between them and the pump. Personally I like the direct mount pumps. But converting the shaft drive mounts to out the back power shouldn’t be that hard. Pto front winches aren’t that uncommon. Personally I’d rather have an onboard generator, a hydraulic winch and forgo the hay tedder option.
   / Would you buy a Kubota work truck? #126
Maybe Ford should come out with a Kubota branded truck.... :confused3:
I hope it will be equipped with a big water pump in case theres a flood.
   / Would you buy a Kubota work truck? #127
Ya most of the dumps now use the direct mount pumps...
   / Would you buy a Kubota work truck? #128
Another butt ugly over priced truck.
I'm not really a fan of the grill, but it just looks like a truck to me - not ugly, not pretty, just a truck. But then I don't buy a truck to win a fashion contest.
   / Would you buy a Kubota work truck? #129
Can you show me the PTO front winches they arent that uncommon? I’d like to look at the cost.
Hay Tedder option? If you are referring to my post, Im talking about a PTO out back of the truck to run something like a hay Tedder. Just one of those frivolous things we farmers do to make feed hay for the food system. :rolleyes:
If the theoretical Kubota work truck had PTO front & rear, it would be a BIG selling point
   / Would you buy a Kubota work truck? #130
There’s about zero of them on passenger trucks. I see them on utility trucks.
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2019 Ram 1500...
WB Mower (A50120)
WB Mower (A50120)
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2021 TAKEUCHI TL8R2 SKID STEER (A51246)
2021 TAKEUCHI...
Kuhn FC 4000 RG (A50123)
Kuhn FC 4000 RG...
Pallet Fees (A50775)
