How to properly load a bumper pull deck over trailer?
   / How to properly load a bumper pull deck over trailer? #21
What trailer length are you looking for? You have a 25' load, so with a 25' trailer you will not have any room to make adjustments. I have been hauling my 24' load on a 22' trailer. I don't have as much weight as you do and my load is balanced, but I am planning to get a 30" GN. Locally I can only find bumper pull equipment trailers in 24'
I suppose I’m not in the market for a trailer unless I get a raise or find $5000 on the street.
My tractor is around 14-15ft I think with bucket on the ground to the rear tires. The bush hog is 7ft wide and 10ft long so if I take both on the road without getting cleaver making 2 trips, load is close to 25ft-ish last time I measured them separately.
   / How to properly load a bumper pull deck over trailer? #23
I cut many properties in a 20 mile radius of my home base.
I can load any of my farm tractors on my gooseneck trailer, chain them down, hit the road, park, unchain/unload and begin work.
I have found after many years of doing that, Id rather just drive the tractor over the road, cut customers property, and drive home. Since its a cab tractor, I have the opportunity to do that in all weather. Also have decent road speed 2 go 24MPH and the MF will do 34MPH.
I would encourage anyone who is considering a custom mowing business to order a HVAC cab, equipped with road safety equipment to do the same. You can lower your costs of truck and trailer and parlay that into a cab and a “road speed” tractor.
I still use the truck & trailer if the trip is > ~10 miles.
You can say all you want about tire wear, but I put 300 hours on my 2 smaller tractors each per year and the tires are holding up very well.
   / How to properly load a bumper pull deck over trailer? #24
I drive mine 6 miles each way to my father in laws once a month to hog his 6 acres. It's same time and less work as trailering. Plus I can hog the berms and clean up what the Boro no longer does. Mines just a little B2650, so around 12mph is topping it out. 20201119_130719.jpg
TEST YOUR BID BUTTON! (A52708)
TEST YOUR BID...
2000 Mack CH13 (A56435)
2000 Mack CH13...
Country Line 3 Point 48" Brush Cutter, 540 PTO, Asset# 63 (A59076)
Country Line 3...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
New Wolverine 3Pt hitch Receiver (A59000)
New Wolverine 3Pt...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
