Bush Hog and a 1977 B7100
   / Bush Hog and a 1977 B7100 #1
tom39
1977 Kubota B7100
I have a 1977 B7100 4x4 and am wondering if it would be capable of running a 4' bush hog?
Thanks
Tom
   / Bush Hog and a 1977 B7100 #2
Tractor data shows 13hp for your pto ,The rule of thumb is 5 pto hp for every foot of cutter . So it would work if you went slow or not take a full cut on the heavy grass and weeds..:2cents:
   / Bush Hog and a 1977 B7100 #3
Thanks
Tom
In some conditions but it will be happier with a 42".
SDT
   / Bush Hog and a 1977 B7100 #4
3 point hitch rear lift is 400 lbs so you need a lightweight cutter and front weights or loader...
   / Bush Hog and a 1977 B7100 #5
I used to run a 40" mower on a B7000 some time ago. It was a nice match for it. Enough to cover the tracks but not too big to overload the tractor.
Thank you all for the responses. I haven't purchased the cutter yet so I will look into something a bit narrower. I do however have front weights that I hang when I use my 3-point hitch scoop to move dirt, rock and materials.
Thanks again for your help.
Tom
   / Bush Hog and a 1977 B7100 #7
Tom
Shouldn't be a problem , i run a 5' on mine.
Well that is good to know. What I was finding was that the 42" is less common and seems to be more expensive.
Thanks for responding
Tom
   / Bush Hog and a 1977 B7100 #9
Just get a 4 foot cutter and go easy.........:)
   / Bush Hog and a 1977 B7100 #10
FYI I have a B7200 (14hp at pto) an old JD54 48" rotary cutter (very heavy) it lifts it just fine and cut great. I have 3 front weights on it.
Good Luck
David
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
JOHN DEERE 333G SKID STEER (A52472)
JOHN DEERE 333G...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A52748)
Toyota 6FGU25...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A51692)
2007 Ford E-450...
