Bush Hog and a 1977 B7100
   / Bush Hog and a 1977 B7100 #1
tom39
1977 Kubota B7100
I have a 1977 B7100 4x4 and am wondering if it would be capable of running a 4' bush hog?
Thanks
Tom
   / Bush Hog and a 1977 B7100 #2
Tractor data shows 13hp for your pto ,The rule of thumb is 5 pto hp for every foot of cutter . So it would work if you went slow or not take a full cut on the heavy grass and weeds..:2cents:
   / Bush Hog and a 1977 B7100 #3
Thanks
Tom
In some conditions but it will be happier with a 42".
SDT
   / Bush Hog and a 1977 B7100 #4
3 point hitch rear lift is 400 lbs so you need a lightweight cutter and front weights or loader...
   / Bush Hog and a 1977 B7100 #5
I used to run a 40" mower on a B7000 some time ago. It was a nice match for it. Enough to cover the tracks but not too big to overload the tractor.
Thank you all for the responses. I haven't purchased the cutter yet so I will look into something a bit narrower. I do however have front weights that I hang when I use my 3-point hitch scoop to move dirt, rock and materials.
Thanks again for your help.
Tom
   / Bush Hog and a 1977 B7100 #7
Tom
Shouldn't be a problem , i run a 5' on mine.
Well that is good to know. What I was finding was that the 42" is less common and seems to be more expensive.
Thanks for responding
Tom
   / Bush Hog and a 1977 B7100 #9
Just get a 4 foot cutter and go easy.........:)
   / Bush Hog and a 1977 B7100 #10
FYI I have a B7200 (14hp at pto) an old JD54 48" rotary cutter (very heavy) it lifts it just fine and cut great. I have 3 front weights on it.
Good Luck
David
Hester 1206 10' V Disc (A50121)
Hester 1206 10' V...
2018 Bobcat T595 (A50120)
2018 Bobcat T595...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
378751 (A51573)
378751 (A51573)
2018 Ford F-550 Truck Altec AT40G 40ft Insulated Bucket Truck (A50323)
2018 Ford F-550...
