Smaller metal cutting bandsaw thoughts?
   / Smaller metal cutting bandsaw thoughts? #32
Reading that, I envisioned five horses going in circles outside with drivetrain of belts and pulleys. Thought, that's a bit overkill, no?
I got my 120 Volt Stihl chain saw at an Estate Auction for twenty bucks Canadian. Have not used it in three (at least) years I think.
   / Smaller metal cutting bandsaw thoughts? #33
Don't see them come up on CL or FB often. I picked up this 7x12 Clarke a while back for $300.
Thats me too. Chineseum Clarke... I've cut literally tons (and I mean TONS) 0f structural shapes and stainless rod on mine. Lost the cheapo Chinese rice paper insulated motor pretty quick, it stunk the shop up, replaced it with a Marathon and the pivot axle the the head swings on, had to machine a new one of those and finally roller bearings in the upper bandwheel but over all, it's a solid saw. I use either Lennox or Starrett pre welded bandsaw blades, varible pitch bi-metal.
   / Smaller metal cutting bandsaw thoughts? #34
I used to have a couple of import horizontal 7x12 bandsaws that I used for twenty years.
I sold them after I finished refurbishing this swivel head Ellis.
I doubt I’ve used my bandsaw more than a couple of times since I bought my Makita dry cut saw
Sorry the pics are out of order.
   / Smaller metal cutting bandsaw thoughts? #35
I say that shop is way too clean and nice and you really just cook Meth!
Rewatching Breaking Bad, Reminds me of Chicken Mans underground Lab!
   / Smaller metal cutting bandsaw thoughts? #36
I'm with you on the breaking bad comparison. Seen BB's shop and something it going on... I just can't figure out what? :D
   / Smaller metal cutting bandsaw thoughts? #37
   / Smaller metal cutting bandsaw thoughts? #38
I've had a HF 4x6 bandsaw (green) for around 12 years. The saw it's self worked great out of the box, but the motor was weak. I finally smoked it when I left it unattended in a cut and the blade hung. I replaced it with a motor with a thermal overload shut off. If I was starting over, I'd look for one with thermal overload protector to begin with.
   / Smaller metal cutting bandsaw thoughts? #39
I'm just looking forward to using the Chicago Electric 4x6 bandsaw that I bought 2 years ago for $60... and the shop it's going in in general :)
   / Smaller metal cutting bandsaw thoughts? #40
I was checking out the craigslit and someone at least within driving distance had a Ramco 8x13. Bigger than what I was going for, but I see your point. 1200 OBO
Ramco was a generic brand often sold off of the back of trucks by rather unscrupulous individuals. They are more bandsaw shaped objects than a real saw. With a lot of work, you can make them work sort of ok, but you are much better off starting with a better saw.
Hustler Zero Turn Mower (A51573)
Hustler Zero Turn...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A53472)
Neckover GL24-2-7K...
JOHN DEERE 461R LOT NUMBER 61 (A53084)
JOHN DEERE 461R...
2016 CATERPILLAR 308E2 CR EXCAVATOR (A51246)
2016 CATERPILLAR...
2013 FREIGHTLINER CASCADIA SLEEPER (A52576)
2013 FREIGHTLINER...
50ft Fuel Line (A51573)
50ft Fuel Line...
