I couldn't help but notice what appeared to be some comments about it being a PITA to set up and/or change dies on the single-stage press, such as the RCBS Rock Chucker. I'm not seeing why it is supposedly a pain. All of my dies have locking rings on them. You set the die up once and then lock the ring in place (typically with a supplied set screw). From that point on, just screw the die into the top of the press until hand tight and you are good to go. I have dies I use in my Rock Chucker that I've not adjusted since the 1970s. How is that a PITA?
I also run a Dillon 650 press. You have to set up those dies too.....once.....just like in a single stage press. And they all have locking rings too!
OK, I'm done with my reloading rant.
