Grandpa, tell me bout the good ole days............
Status
Not open for further replies.
   / Grandpa, tell me bout the good ole days............ #711
This is what the bulk oil bottles looked like at the gas stations.
   / Grandpa, tell me bout the good ole days............ #714
Curiously, how do they compare in standing up to road salt?
Better, Concrete spalls from pressure of rusting rebar asphalt don't have rebar. Other side of the line, asphalt bubbles when brine seeps into joint between layers due to poor laying job and snow plow shaves bubbles off.
Asphalt is plastic, concrete is solid so asphalt moves from tire wear. Also suffers UV light damage. Biggest problem is LOW BIDDER. Asphalt only good to lay in temperature range but low bidder don't check temperature or reject cold load. You see it year or so later. Lazer on layer screws up you see after first rain. Inspector already spent bribe so nobody cares.
Concrete pothole can be cut out, pinned and repoured, but rarely gets done.
Salt only a problem if brine reaches rebar. See it a lot on bridge decks. Proper concrete placement solves problem most times. LOW BIDDER creates problem most times. Bridges get built to be rebuilt & create jobs for Laborers. Laborer Union good political contributor. Taxpayer bottomless pocket. Truck road tax bottomless pit. 120 day job to replace bridge deck wid jackhammers, 80 days wid machine from Canada. Guess how dat job gets bid.
1980s CAT built mile long machine, chews top layer off superslab, runs old stone thru heater den into mixer, followed by Pavement heater den into layer followed by fleet of rollers. Hour after shaving brand new surface and if job done right, properly stuck to base. System fell out of favor fast, eliminated Union jobs. Probably went to China by now to come back as paperclip.
I don't think they are rebuilding stoves anymore, either. We have a couple of old "Round Oak" stoves that my BIL thought about bringing there, but the last time I knew he hasn't been able to get in touch with them.
Might have something to do with the owners pass on last year and year before....
Curiously, how do they compare in sharpening up the state of ME snow plow cutting edge?
   / Grandpa, tell me bout the good ole days............ #717
LoL...Obviously "some" peeps have never read or seen a state or federal DOT (paving) contract or the included specifications...OR worked with a winning bidder on said contracts and with the required on site state or federal inspectors etc... because they obviously have no clue what they're talking about...!
   / Grandpa, tell me bout the good ole days............ #718
HAHAHHAA!!!
YES!!! And that's AFTER they ground it down. :laughing:
For those of you that don't know what we're talking about, there's a stretch of concrete highway that somebody must have messed with the level line on the concrete machine or something, because as you drive along, your car starts rocking up and down for about half a mile. Then it stops for a few hundred yards and you start rocking again. It was really bad after it first opened, and they ground it down some, but it continues to this day.
When Rieth & Riley paved that section, they put a new guy on the concrete paver for a day. They had stout cord stretched between stakes every so many feet that was set to the grade for the paver to follow. Obviously, the cord would sag between the stakes, but the machine had a setting to adjust for the sag. However, the new operator didn't know about it and didn't turn it on, thus, the machine followed the sagging cord for around a mile before the regular operator was back on the machine.
When the DOT saw the dips, they wanted R & R to tear up the whole mile and replace it, but R & R talked them into letting them mill it down to remove most of the unevenness. It helped, but it is still very noticeable, especially in a big truck. I believe that it was milled again a few years back, but it's still like a roller coaster.
   / Grandpa, tell me bout the good ole days............ #720
I wondered about that. Every paving job that I see has a DOT inspector with his little testing machine to ensure the right density and ? I don't believe they are allowed to pave unless the inspector is on site.
Status
2015 Kia Sedona Van (A51694)
2015 Kia Sedona...
2011 Mercedes-Benz E550 Sedan (A51694)
2011 Mercedes-Benz...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2007 FREIGHTLINER BUSINESS CLASS M2 T/A DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2014 Ford E-350 16ft Box Truck (A51692)
2014 Ford E-350...
2006 BIG TEX 16 T/A TRASH TRAILER (A53843)
2006 BIG TEX 16...
