Replacing Shaft Seals on Log Splitter Control Valve
   / Replacing Shaft Seals on Log Splitter Control Valve #1
WranglerX
Super Member
A Little Bit West Of Yosemite NP
MF GC1715
Any body have any experience replacing "O" rings on a log splitter control valve?.... Any thing I need to be aware of before I order set of "O" rings and attempt to fix the leak at the shaft... It is a "Energy" brand control valve if it makes any difference...
Dale
   / Replacing Shaft Seals on Log Splitter Control Valve #2
   / Replacing Shaft Seals on Log Splitter Control Valve #3
Pretty straight forward.
Id take the o-rings out and take to your favorite supplier. IF just o-rings, a napa or something. But sometimes they have quad rings or x-rings. hydraulic shop for those most likely
It seems those valves have directional O-rings. Be sure to get them oriented correctly.
This may help: http://www.energymfg.com/pdf/44833x.pdf
Thank you, but I have most of the files Energy has to offer and some are not much help, they could not even give my specs on my (their) control valve and I had all the numbers for them....
Dale
2018 CATERPILLAR 12M3 MOTORGRADER (A52709)
2018 CATERPILLAR...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
Case 870 Agri King Loader Tractor (A59814)
Case 870 Agri King...
2018 Grove TMS 700E 60 Ton Quad Axle Crane Truck (A60460)
2018 Grove TMS...
Volvo A40D Off Road Dump Truck (A56438)
Volvo A40D Off...
