Replacing Shaft Seals on Log Splitter Control Valve
   / Replacing Shaft Seals on Log Splitter Control Valve #1
WranglerX
Super Member
A Little Bit West Of Yosemite NP
MF GC1715
Any body have any experience replacing "O" rings on a log splitter control valve?.... Any thing I need to be aware of before I order set of "O" rings and attempt to fix the leak at the shaft... It is a "Energy" brand control valve if it makes any difference...
Dale
   / Replacing Shaft Seals on Log Splitter Control Valve #2
   / Replacing Shaft Seals on Log Splitter Control Valve #3
Pretty straight forward.
Id take the o-rings out and take to your favorite supplier. IF just o-rings, a napa or something. But sometimes they have quad rings or x-rings. hydraulic shop for those most likely
It seems those valves have directional O-rings. Be sure to get them oriented correctly.
This may help: http://www.energymfg.com/pdf/44833x.pdf
Thank you, but I have most of the files Energy has to offer and some are not much help, they could not even give my specs on my (their) control valve and I had all the numbers for them....
Dale
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
Utility Cart (A59228)
1994 JAGUAR XJ-SERIES (A58214)
1994 JAGUAR...
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
2018 John Deere 1653 (A56436)
2018 John Deere...
1608 (A57192)
1608 (A57192)
