Sears Tractor
   / Sears Tractor #11
I didn't see that exact spec. The non electronic ignition models appear to have a magneto coil that is external to the flywheel. It seems a short while back someone was looking to replace an electronic ignition for one of these that were NLA and a guy had a kit on EBay that did just that for - 200$. Just a thought here, but may be more helpful seeing as though you have points. Grab a 12 volt automotive coil from an auto parts store for cheap (~20$) and wire it for battery ignition. + would be switched (start and on) , - would run to the point /condenser terminal. Be sure to remove the lead to the existing magneto coil from that terminal. Know also that with magneto ignition, that switch lead that goes to the point set supplies a ground to kill the engine. You will need a new spark plug wire from the new coil too.
In short to just try this, the only wire that goes to the point set is the - from the new coil. You could just clip the + of the coil to the battery terminal while you what to start and run the engine. If this works out, the + wire to the coil is the one that needs to be switched 12 volts- maybe off the light position on the ignition switch or a new switch put in. This would be a cheap way to give a good hot spark. Ideally, remove the old ignition coil to prevent damage. At the very least, ground the terminal from the old coil to the points.
I'm assuming that the point gap should be set at .020" The breakers could be cleaned and reset for the most accurate timing.
   / Sears Tractor
Your thinking is that the automotive coil will provide a hotter spark than the magneto. If that is the case that would be an improvement and an alternative to an electronic ignition. The optimum would be to get rid of the point and capacitor ignition and no longer having to maintain them.
   / Sears Tractor #13
There's already kits to do just that.
If you use an automotive coil, you'll need a way to trigger it. Tomplum's method uses the points to do that. And you'll need to reduce the voltage to it unless the new coil has a built in resistor. Otherwise, the coil will nuke itself when fed 12v or more when charging the battery. Typically, the old coils were fed battery voltage only during starting. In the run position, the coil was fed 8-10 volts through a resistor or resistor wire built into the wire harness.
YouTube has a plethora of videos to do ignition conversions on small engines. It's a lot simpler than deciding which method to use. :p
   / Sears Tractor #14
What tomplum and Tinhack said. :thumbsup: On most old SGAs timing is adjusted by point gap. Adjusting by a few thou' (less) can ****** it for easier starting. 'Timing' can be way off and still run ok once warmed up, which disguises the starting issue.
Static timing can be checked with the spark plug removed and a VOM connected to the points. I learned 'how-to' in the '60s with Honda motorbikes, no timing light or flywheel TDC mark needed. Important to 'calibrate' first and make changes that can be compared to 'base'. If nothing works better, return to original setting.
If you use a std auto coil, there are 'voltage dropping resistors' to allow full-time 12v operation (Ford, Chrysler) vs the resistor wire used by GM.
Also, I add Sta-Bil to all gas cans when I bring them home. Fuel may go into mower, backhoe, or bucket truck, and not predictably with intermittent use of them. I've been get better starting, as tho' freshly pumped and IMO it's worth the $$. That doesn't seem to be a problem here but we don't always fill up same-day, and if we don't start well with fresh-pumped fuel, we'll want the advantage if it sits for weeks or months.
   / Sears Tractor #15
It occurred to me too that when the old point box Briggs got a little worn, that we set the point gap back to .018 0r .019"
   / Sears Tractor
Decided this morning to start taking it apart, instead of trying to start with the small garden tractor battery I jumped it with a car battery. It started after several tries. I have now taken the shroud off and attached a picture of what I have.
   / Sears Tractor #17
The gap between flywheel and coil is critical. (5-10 thou' seems to work best)
Be sure to clean up the outer surface of the flywheel and faces of the coil irons. (steel wool.etc.)
If there's any contact between, we'd be lucky to get a spark at all.
If the gap is too wide, output will suffer.
btw, who hasn't seen an older lawn tractor with a car battery vs OEM-size on it. :)
   / Sears Tractor #18
Is the head gasket leaking?
   / Sears Tractor
What you are suggesting is that I retain the points and just clean everything up. That is certainly something I could try to see if I get a hotter spark. I wish I had the room for a car battery, the small garden batteries with their low amperage hours just doesn't get it especially in cold weather. I did a load test on the garden battery and it past the test.
   / Sears Tractor #20
I think he meant the gap between the flywheel and the armature of the coil.
I always inserted a business card and tightened the armature down with it in place. No idea how thick they are.
2013 ISUZU NPR STAKE BODY TRUCK (A54313)
2013 ISUZU NPR...
Adams 6T Fertilizer Spreader (A55301)
Adams 6T...
2013 BMW X5 xDrive50i AWD SUV (A53424)
2013 BMW X5...
2020 Chevrolet Silverado 3500 HD 4x4 Service Truck (A52377)
2020 Chevrolet...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
