Open Center vs Closed Center
   / Open Center vs Closed Center #1
Oiltech
La
Kubota L3540HSTC, M7060HDC-12, ZD331-72, Bobcat E42
How do I determine what design hydraulic system is on my tractor? It's a Kubota M7060 HDC12.
   / Open Center vs Closed Center #2
open center........
   / Open Center vs Closed Center #4
X3 open center. Majority of tractors have open center hyd's because open center hyd system is less expensive to build & less complex to diagnose if problems arise.
   / Open Center vs Closed Center #5
Ditto on that. Closed center systems require all manner of gismos and whatnots. If the pump is pumping, the oil has to go somewhere. :laughing:
   / Open Center vs Closed Center #6
Tractordata.com will tell you. All replies are same too :thumbsup:
   / Open Center vs Closed Center #7
If JD closed center hyd system is operating correctly when stand-by pressure is attained with no internal/external leaks hyd pump shaft continues to rotate but pistons are forced away from shaft by pump crankcase pressure therefore causing hyd pump to stop pumping oil
   / Open Center vs Closed Center #8
Yeah, that type of pump falls into the "gizmo" category. ;)
   / Open Center vs Closed Center #9
That type of pump set John Deere apart from the rest of the Ag Equipment industry and was a major factor of the company's meteoric rise to the position of North American leader which it has maintained for about 6 decades.
   / Open Center vs Closed Center #10
Tinhack
Just because the CC pump has a stroke control valve & inlet/outlet valves doesn't classify it as "gizmo" category to me. But I understand how a closed center hyd system was designed to function. My JD 4255 which has a similar CC hyd pump that I've owned since Feb. '93 has over 11,500 hrs on original(untouched) hyd pump that I could purchase a ""new hyd pump"" for a little over $500. Can you purchase a new hyd pump for either one of the tractors for $500? I'll bet it can't happen.
Jim
2008 PETERBILT 367 FLAT TOP SLEEPER (INOPERABLE) (A55745)
2008 PETERBILT 367...
2018 ASV RT120 Skidloader (RIDE AND DRIVE) (A50775)
2018 ASV RT120...
KUBOTA SSV65 SKID STEER (A52706)
KUBOTA SSV65 SKID...
2004 Honda Civic Coupe (A55758)
2004 Honda Civic...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55302)
Kubota SVL65-2...
