Belt driven Hydraulic Pump, manufacturer and specs needed.
   / Belt driven Hydraulic Pump, manufacturer and specs needed. #21
There was a guy who was re-purposing a 6gpm or so OC setup. IIRC his res was 6-8 gal and fluid got hot w/o operating any cylinders.
Seems he'd added a pressure gauge between pump and stack, but plumbed it into 1/2" lines using a 3/8" tee. I never got over thinking he'd placed an unnecessary 'throttle' in a 'worst' possible place.
Gauge pressure seemed as expected, but that says nothing about flow beyond the narrow Tee. I'd expect a considerable amount of oil was going through the relief valve adding to the heat.
I don't recall reading if the hot hydro issue was ever overcome. :confused:
   / Belt driven Hydraulic Pump, manufacturer and specs needed. #22
Aaron
Looking at valve pictures I would estimate that casting to be 10 - 12 GPM but That is just a guess. A lot of older valves were in the 10 - 12 GPM range or larger. I don稚 recall seeing very many for lower flow. Part of this is due to running lower pressure 1250 - 1750 PSI range which requires larger cylinders that we see on systems today
Number of valve spools or sections also must be considered when sizing valves for pressure drop.
Good luck on this project
Aaron
Thanks, leaning heavily towards making it a three-point mount and the tractor it would go on (L3830) has 8GPM available, so it being a 10-12gpm valve would be perfect.
Aaron Z
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
Kubota LX2620 (A53317)
2014 Nissan Altima S Sedan (A55853)
2014 Nissan Altima...
2011 GMC Sierra Ext Cab 4X4 Pickup Truck (A55852)
2011 GMC Sierra...
8' LARGE FENCE POSTS (APPROX. 20-25 PC) (A54757)
8' LARGE FENCE...
2020 Kubota SVL75-2 Compact Track Loader (A55314)
2020 Kubota...
