Belt driven Hydraulic Pump, manufacturer and specs needed.
   / Belt driven Hydraulic Pump, manufacturer and specs needed. #21
There was a guy who was re-purposing a 6gpm or so OC setup. IIRC his res was 6-8 gal and fluid got hot w/o operating any cylinders.
Seems he'd added a pressure gauge between pump and stack, but plumbed it into 1/2" lines using a 3/8" tee. I never got over thinking he'd placed an unnecessary 'throttle' in a 'worst' possible place.
Gauge pressure seemed as expected, but that says nothing about flow beyond the narrow Tee. I'd expect a considerable amount of oil was going through the relief valve adding to the heat.
I don't recall reading if the hot hydro issue was ever overcome. :confused:
   / Belt driven Hydraulic Pump, manufacturer and specs needed. #22
Aaron
Looking at valve pictures I would estimate that casting to be 10 - 12 GPM but That is just a guess. A lot of older valves were in the 10 - 12 GPM range or larger. I don稚 recall seeing very many for lower flow. Part of this is due to running lower pressure 1250 - 1750 PSI range which requires larger cylinders that we see on systems today
Number of valve spools or sections also must be considered when sizing valves for pressure drop.
Good luck on this project
Aaron
Thanks, leaning heavily towards making it a three-point mount and the tractor it would go on (L3830) has 8GPM available, so it being a 10-12gpm valve would be perfect.
Aaron Z
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
2005 Chevrolet Trailblazer EXT 4X4 SUV (A55853)
2005 Chevrolet...
2018 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2018 DRAGON 150...
2016 Jeep Wrangler Unlimited SUV (A55853)
2016 Jeep Wrangler...
1973 JEEP RENEGADE (A51247)
1973 JEEP RENEGADE...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
