Felling a leaning tree to the side of the lean
   / Felling a leaning tree to the side of the lean #21
Mosst people rigging to pull a tree forget that once it starts to fall the pull is gone as the pull vehicle isn't fast enough to keep the slack out of the cable.
True, that's why it's essential to have aimed the tree accurately with proper sized hinge wood and "safety valves" in place, be it wedges, jacks or what have you.
The guy line is just a tensioner for that initial breaking of the hinge at which time, due to your careful pre-falling procedures, the tree falls where aimed.
Of course, with rotten wood, all bets are off.
   / Felling a leaning tree to the side of the lean #22
It's cheating if you use a rope. I couldn't find the video where they get a tree to fall 180 degrees from the lean, but this gives you an idea.
   / Felling a leaning tree to the side of the lean #23
   / Felling a leaning tree to the side of the lean #24
   / Felling a leaning tree to the side of the lean #25
The dutchman can be a really useful tool when used correctly same as a sizwheel. Myself I’ve used these techniques as well as jacks a lot more then a line but I’m also a timber faller not an arborist.
   / Felling a leaning tree to the side of the lean #26
I wish I could have the found the video I saw a few years ago. It was a large leaning tree on a steep slope, The feller did those Dutchman cuts and you could watch it to fall in the direction of the lean, and then in slow motion "spin" around in its direction and fall 180 degrees away from the lean. It was a thing of beauty.
I am amazed at what the fellers and arborists do.
   / Felling a leaning tree to the side of the lean #27
I hate White Pine, they snap / break off instead of falling like a normal tree...
Exactly! Hinges only work if they hold, and bend, or break in a continuous order, to direct the fall.
On white pine I’ve dealt with, the hinge snaps off early and then the tree is just going to fall where gravity takes it.
Even with my skidding winch hook high on the tree, I could start tree in intended direction, but once hinge snaps you can’t winch fast enough to fight gravity with no hinge holding wood directing it.
The bigger the angle you’re trying to redirect, the worse outcome you may get.
Luckily I only dropped it on an old useless barbed wire fence and wasn’t playing for keeps, like when there’s a building or power lines around.
   / Felling a leaning tree to the side of the lean #28
Would it be this one? Heck with wedging - YouTube
   / Felling a leaning tree to the side of the lean #29
I'm a firm believer in ropes, especially as I'm usually working alone and near buildings (and ropes are cheap). CMCpro.com sells leftover 1/2" climbing rope for about $75 for a 50lb box (500' plus) plus $26 shipping. Normally goes for over $1/foot. It's at Sale - Rope Miscellaneous Sections | CMC PRO. I've bought 2 boxes of darn good 1/2 and thicker climbing rope/rescue rope.
I can't throw a throw line worth a hoot, so I usually use a weighted line with a slingshot.
I've got lot's of ropes, so I'll often use two and some come-alongs to make sure the tree gets started in the right direction.
   / Felling a leaning tree to the side of the lean #30
Ropes can work in hardwoods but in the big softwoods good luck getting a line around a tree. When I have used a line it’s been a drum line off a D7 sized cat anything smaller I wouldn’t even consider I can cut a jack seat faster and have a gauge I can watch what’s going on.
2016 CATERPILLAR 330 FL EXCAVATOR (A60429)
2016 CATERPILLAR...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
FENCE PANELS (A58214)
VOLVO A25G OFF ROAD DUMP TRUCK (A60429)
VOLVO A25G OFF...
2016 JOHN DEERE 35G EXCAVATOR (A60429)
2016 JOHN DEERE...
