Switch jumper help
   / Switch jumper help #1
Strummer
Strummer1%
Doing some trouble shooting , need a hand with a switch . How should I jump this switch ? IMG_8369.JPGIMG_8368.JPGIMG_8373.JPG
   / Switch jumper help #2
Got an ohm meter for testing?
Which lead carries the power?
Jump that one to whichever lead carries the ground.
Bob's your uncle!
   / Switch jumper help #3
You need to find the wires that go to the normally open contacts in the switch.
Bob's your uncle!
Dang my meter is in my truck at buddies shop . Getting some work done . I’m meter less for a few days .
I did clean the heck out of it . Was packed full of mud . That might of been a big part of the problem.
   / Switch jumper help #6
What switch?
What problem?
What switch?
What problem?
It’s the seat switch . Trying to trouble shoot my intermittent starting/ not starting issue
   / Switch jumper help #8
If that's the pigtail that goes to the switch and you are asking how you would jump it out after you determine it is your problem....if you can't find a mating connector like that to make a jumper harness you can get some crimp on disconnect lugs and jump the terminals out that would normally be the switch legs.
I want to jump it out to see if it’s my problem. If it is I will replace the switch.
2006 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F750 XLT...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
2014 716PT Homesteader 7'x16' Box Trailer (A52384)
2014 716PT...
HYD PUMP & TANK SET (A51248)
HYD PUMP & TANK...
2000 SCHWING P88 PORTABLE CONCRETE MIXER (A51247)
2000 SCHWING P88...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A53472)
Texas Post Driver...
