Lift for Barn/Shop
   / Lift for Barn/Shop #1
TxFig
Member
Texas
John Deere 3032e
I have a metal building that serves as my workshop / barn / man-cave that has on one end, a loft about 10' up. It's open with no rails around it. It is simply there for me to store stuff to keep it out of the way until I need it
(for example, the extracting equipment I use for honey bees).
As I get older, the joy of using a ladder to get up to the loft and hauling stuff up & down is diminished from my younger day. So I have started looking for a "lift system" (diy freight elevator). It does not need to be especially heavy duty - lifting AT MOST 500 lbs (half of which is *ME*). I found several dozen on youtube, but most seemed to be way overbuilt for what I need. I did find THIS video, which looks to be close to perfect:
Sadly, that video is from 8 years ago and has close to zero information about where he bought it (it looks to be a kit of some sort).
So I'm turning to this group (one of the most useful places on the 'net). Any ideas on how to build (or purchase) a system like this?
   / Lift for Barn/Shop #2
Here is another one:
Perhaps a stairway? Fill the center section in to add more floor/storage space.
I'm pretty sure I said "I don't want to carry stuff up and down" in my original post.
   / Lift for Barn/Shop #5
Do you have enough room or use for a small propane forklift?
   / Lift for Barn/Shop #6
Depending on what they cost a car lift may be more useful. Put your tractor on it and use the bucket or forks for the rest of the height. Mine goes 8 feet up. And it will make servicing your cars and tractor easier.
   / Lift for Barn/Shop #7
This is what I used, but didn't need to ride on it: https://duckduckgo.com/?q=crank+up+material+lift&t=h_&iax=images&ia=images
I guess you could replace the hand winch with an electric winch and be able to ride on the lift.
   / Lift for Barn/Shop #8
I’d be inclined to buy a small forklift and either fix it up to be useable or take the mast and use it.
   / Lift for Barn/Shop #9
Not exactly. Carrying stuff up and down stairs is a whole lot different than doing it on a ladder.
And even at that, use the stairs for you and a simple hoist for the materials. HF has an 800 pound electric hoist for less than $200 that you could rig through a trap door kind of thing.
   / Lift for Barn/Shop #10
Years back I was selling forklifts.
Very popular whenever we scrapped a truck was the lift mechanism as once firmly attached to floor and at the top all that a buyer had to do was add a hydraulic pump and presto an elevator.
As you probably know electric hydraulic pumps are readily available and reasonably priced and offered in 12/24 VDC as well as 110/220 AC.
To operate a fork lift 'lift' only a single action pump was required as forks lowered by gravity.
In the last couple of years I've been involved in modifying 2ea 4 post car lifts into freight elevators.
Fun and satisfying projects.
Since public will be involved we had to install lots of safety interlocks and limit measures.
Might add that a fork lift 'front' should probably fetch low scrap value due to the mix of materials/components that would want fair labor prior to being ready as 'clean scrap'.
I recall that smelters would only accept cut up chunks in the 2 square foot size due to furnace door limits.
Informational Lot - Financing (A53472)
Informational Lot...
New/Unused CFG Industrial MH12RX Mini Excavator (A51573)
New/Unused CFG...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2001 Ford F150 (A50121)
2001 Ford F150...
KUBOTA BX2350D TRACTOR (A51247)
KUBOTA BX2350D...
2017 Kia Cadenza Premium Sedan (A51694)
2017 Kia Cadenza...
