Fuel transfer tank pump
   / Fuel transfer tank pump #1
887
Member
canada
montana r3644
So setting up a 50 gal transfer tank from a old f700 ford truck. Wanting to keep this project on the cheaper side, I'll be using it to fill a couple 150+hp allis chalmers tractors and a gleaner combine. I have been using a bunch of jerry cans(crazy I know) and want something easier. Will I regret getting a hand pump vs a electric? I could see issues keeping the nozzle in the combine which is up top while pumping down in the pickup.
And If I do go with a hand pump, is the piston or rotary better? looking into fillrite since they seem to be made good and last.
I'm in canada and the hand pumps with hose and nozzle are around $250 cad. The 12v looks to be around $450 cad at the cheapest.. Although I did find a RD812 smaller one for under $400.
Just looking for suggestions, thanks
   / Fuel transfer tank pump #2
I use an $18 (USD) 12v submersible diesel pump, and some clear 3/4" tubing to pump up my stuff. Been using it for 3 years. Pumps about 10 gpm and has a toggle on/off switch. I use it to pump out of a 275 gal storage tank. Several on ebay to choose from.
With only 50 gal to pump, I wonder if you're not doing a little "overkill" with the nozzle and 110v elec pump.
Just my 2「.
   / Fuel transfer tank pump #3
I gave up with hand pumps, non auto shut off nozzles, and cheap electric pumps. I have used a FillRite 12v pump with an auto shut off nozzle for the past 10 years or so.
They're not cheap, but it works when I need it, plus I don't spill diesel by overfilling.
I do have a rotary vane hand pump I use for my "strategic reserve" fuel. Made by GPI, 13 or so revolutions per gallon. I wouldn't want to use it daily, or for more than a few gallons at a time though.
   / Fuel transfer tank pump #4
I discovered a nice VERY reasonably priced pump on the net.
It basically is a marine bilge pump c/w filter screen, 12 or 24 volts wired with switch and battery clamps.
Not super fast but very acceptable flow.
Best yet is price, as it is in the $10.00 (US) range.
Being submerged it is a big NO-NO for gas.
One TBN'r also found one on Google Prime as well.
They are so compact that they fit in the filler necks of most fuel containers.
Another nice feature is they self drain back to the fuel tote thus no smelly spillage.
   / Fuel transfer tank pump #5
Just my 2「.
I just ordered a 12V pump for diesel, on E-Bay, that will fit through a standard size barrel bung...pump hooked to hose drops into the tank.
It cost me $15 USD, and has good reviews.
I believe that these (11 gpm?) 1-1/2" (?) diameter pumps are also sold by Princess Auto in Canada, and may be even cheaper there.
Made in China, of course!
   / Fuel transfer tank pump #6
I buy the GPI 15GPM/minute electric. I have one mounted to a 100 gallon on one truck and another mounted to a 50g cube on another truck. I think they are $299 at Tractor supply. I get about 5 years out of them, but they are used a LOT. I kept the box and receipt for the last one I bought and it’s getting returned if it’s gives me any issues.
   / Fuel transfer tank pump #7
I like Fill-Rite pumps, I have had very good luck with them.........
   / Fuel transfer tank pump #8
Just my 2「.
yes and no, I may end up with a 100 gal tank down the road. And a good pump can usually be resold for a fair bit if I need to. Not sure if you've ever filled up combines with the fuel tanks up top but it's a pain. Will be 12v pump not 110.
I will look into that, I really wanted to keep this project cheap and the pump part is the most expensive since I got the tank for free. I guess I'm just skeptical of the cheaper pumps, I just want something that's going to work when I need it
   / Fuel transfer tank pump #10
Yes they are better than GPIs
I prefer Fill-Rite pumps, I spent a lot of money on GPI pumps and finally replaced it with a Fill-Rite.
Also, since you'll be filling tanks "away" from your pump, you'll need to be able to shut it off at the nozzle. I have a 36 gal aux tank in my truck I pump out of and can't see how a manual pump would work very well.
The electric pumps have a limited time they can be deadheaded. Don't remember the time, but enough to stop the flow and shut off the pump
RIGID TOOLBOX (A52472)
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2021 Allmand Bros...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
2016 Freightliner M2 106 Ambulance (A53422)
2016 Freightliner...
2008 CATERPILLAR 12M MOTOR GRADER (A51406)
2008 CATERPILLAR...
2025 Wabash 450 Gallon Skid Mounted Vacuum Tank (A52377)
2025 Wabash 450...
