Nearly went over.
   / Nearly went over.
Did you have anything on the rear before you picked the load up?
Only a tow hitch but tyres about 80% water for ballast, have lifted round bales and 750kg bulkers many times without the rear lifting, did not know these were heavier, they all look alike and 750kg is a standard size.
   / Nearly went over. #22
   / Nearly went over. #23
Stupid people almost always continue to do stupid things......and (removed) fits that definition!
WOW !!!!
That is unnecessarily NASTY/HARSH!
A TOTAL INSULT!
I would venture a guess that (removed)'s IQ might actually be higher than yours!
   / Nearly went over. #24
Filled tires don't do much for lifting. You need weight on the 3 point.
   / Nearly went over. #25
Yes, (removed). You could be making a good point but I've given up trying to translate. It's lost in the wind ................
I did that kind of thing years ago, like 30, when all we had out here was chat rooms and bulletin boards.
I don’t even read his posts.
Whatever he’s trying to say is lost to me.
When WHAT you’re trying to say become secondary to HOW you’re trying to say it, the reader gets lost in translating the subject material.
Sam Clemons was a brilliant man but lost a lot of his readership with his style of delivery.
   / Nearly went over. #26
They help quite a bit vs nothing but tractors need substantial rear ballast to utilize the FEL and loaded tires aren’t enough by themselves.
   / Nearly went over. #27
Thank god it turned out OK for you.I always use a ballast weight plus my loaded tires when lifting heavy loads.Good lesson learned..
   / Nearly went over. #28
Right click on (removed)'s icon - open in new tab - click on ignore === problem solved as long as someone doesn't Reply With Quote
   / Nearly went over. #29
I really try and remember to put the lap belt on, just incase I drop into something and don't want to become a cushion for the tractor. It might be because i live on sloped uneven ground.
   / Nearly went over. #30
G'day Bunyip... filling an empty counterweight/ballast-box with sand will be OK-ish but it will depend on the coarseness of the sand, which will settle over time and usage.
A few bags of mixed cement would be better and you can add a couple of upright poly tubes to carry some handled tools if you'd like. There are a number of TBN threads showing what other Members have done.
I've used bricks in mine. I'm also keeping my eye out for a used/broken 'weight machine' where I can reuse the rectangular weights to replace the bricks.
2007 Honda CR-V SUV (A53424)
2007 Honda CR-V...
2014 CATERPILLAR 826G LANDFILL COMPACTOR (A51406)
2014 CATERPILLAR...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
2001 John Deere M665 (A50120)
2001 John Deere...
Toro Zero Turn (A50324)
Toro Zero Turn...
2014 CATERPILLAR 289D SKID STEER (A52706)
2014 CATERPILLAR...
