B26 repair of broken u-joint on front drive shaft at HST output
   / B26 repair of broken u-joint on front drive shaft at HST output #1
SamWalton
Sallisaw Oklahoma
Kubota B26 TBL
This U-joint failed and it looks like the repair is super expensive. I have been looking at alternatives to such a labor intensive repair. I am considering cutting out an opening in the plat from the bottom after removing the HST oil tank. Possibly using a plasma cutter to open for repair. This would make it easy to push out pins to remove U-joint. Two large bolts can be removed which support the front axel and wheels. This could give the extra movment of the drive shaft to allow removal and installation of the new U-joint. I am not sure if this will work but the photos and drawing look to support this theory. I have attached pictures and parts diagrams to show how these thing come together. Please, anyone who has done this repair, via dealer or otherwise please share your thoughts and opinions.
I have called the service department of our local Kubota dealer and they are unwilling to provide details on this repair. Also the service manual is not available on the internet and I may purchase a hard copy from the dealer.
  • B26 Tractor Parts Manual.pdf
   / B26 repair of broken u-joint on front drive shaft at HST output #2
How many hours on it? FINALLY hear about another tractor other than JD with failed Ujoint. The one on the engine side of my 4010 JD failed at 660 hours. After that, JD advised greasing them every 50 hours, but you cannot get to the front one. Had the one on the 2025R greased at 200 hours by JD. They had to remove the instrument panel. Removed whole driveshaft because you cannot even get a gun on the rear one unless it is bent 90 degrees.
You don't show any possible access from the top. Bet that is how you get to it. That's how they got the 4010's out. Saw it in the shop. I just traded for the next tractor then.
   / B26 repair of broken u-joint on front drive shaft at HST output #3
I have no ideal how to do your repair.
A few observations from your pictures.
1) your U-joint appears to be full of crud. Even if it is grease from greasing the U-joint(s), if operated in cooler temps and depending on the grease compounds, grease can get very hard just by themselves, add in some dirt and grit from normal operating and you could have it bound up with very solid wad of whatever contributing to failure.
2) not being able to see what is ‘above’ the HST tank or what might be above the plate you plan to cut out, caution with flames when cutting is a HUGE MUST!
3) again a safety caution. Many jack stands have been recalled. Many more are suspect that have not been recalled. Many people are suggesting using various types of blocking material, be aware that every time you put a block on top of a block, you add a potential shift point. Also bases of any support system needs to be on solid non-shifting/moving surface.
   / B26 repair of broken u-joint on front drive shaft at HST output #4
Good luck. I went through this on a JD 2305. Took days to get to the driveshaft and remove it only to discover the cardan joint had been fatally damaged by the U-Joint coming apart. Took it to a driveline repair shop and discovered that JD uses a proprietary (shock!) spline that fits JD, and only JD, PTO shafts. And they wanted $800 for a new one. I was lucky to find that one. A normal repair on a normal driveshaft with standard splines would have been around $100, maybe a little more with balancing, etc.
Went in from the top, removing the seat, the floorboard, the steering wheel and a bunch of other stoopid stuff. It was nutz. Days and days of re-inventing the wheel.
The point of this post isn't to tell you about my troubles but to tell you to not wait until the u-joint destroys the cardan joint, or the yoke.
I don't blame the Dealer for not telling you how to fix it. At all. It's where they make their money, not on new tractor sales. How much are they quoting you?? In hindsight, I would have paid $500 for the fix, if I had it to do over again, but it was easier to sell that piece of junk, after we welded the joint up a bit, to one of the locals who thinks green and yellow is anything but ugly. Told him about the troubles up front, he didn't care.
My next one will be orange. I'm done with people who manufacture goods that only their parts will fit. Not so much that it broke. EVERYTHING breaks, but that you gotta pay through the nose for a one-off design that is no improvement whatsoever over standard. JD loves to do that
   / B26 repair of broken u-joint on front drive shaft at HST output #6
I recently split and reassembled a B20. There are more similarities to the B26 than I would have expected. The tunnel section on mine has 2 hatches on the top, and one on each the left side and the bottom. This allows access to the main shaft U-joint, but the MFWD coupler is harder to access.
I see the B26 has gone to double roll pins from the single pin + wire on the B20. The B21 does it like the B26. I noticed that my U-joint roll pin had broken, tho it had not come apart yet.
I think you should cut a hole. Splitting the B20 was a huge project, as was the B21 I did years ago.
   / B26 repair of broken u-joint on front drive shaft at HST output #8
^^^...my Cub Cadet too.
Great safety observations. Thanks. I have been considering the many safety issues. Each and every time I work around high risk activities.
800 hours
If I pulled the front axel forward the drive shaft should come out completely. If broken and I could learn if the U-joint broke or fell off which would allow you to know if the spline Shaft could be damaged?
2018 MACK CHU613 DAYCAB (INOPERABLE) (A55745)
2018 MACK CHU613...
UNUSED HURRICANE STAND ON SKID STEER (A52706)
UNUSED HURRICANE...
2003 CATERPILLAR D3G XL CRAWLER DOZER (A52707)
2003 CATERPILLAR...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
STAR EV 36V ELECTRIC GOLF CART WITH BATTERY CHARGER (A53424)
STAR EV 36V...
