Massey Ferguson 50 transmission question
   / Massey Ferguson 50 transmission question #1
yanmars
My brother has a MF50. His transmission is "stuck" in first gear, the hi-lo works but he cannot get it out of 1st into any other gear. He changed the transmission fluid he said about 1 year ago, the manual said 27 quarts so that is what he put in. He says the manual does not show a dip stick to check the level. That seems unusual to me but I do not have MF50.
Any thoughts on the transmission issue, he does not think it has external linkage to get in a bind and also the location of a dip stick. Thanks
   / Massey Ferguson 50 transmission question #2
The tractor is supposed to hold 8 gallons of 80w or 90w mineral oil. I believe there is a way to get it out of first. I believe you have to pull the fill plug and use a strong and lengthy screw driver to pry it. Try looking on yesterdays tractor forms, as they are more about tractors of the past. I do believe there are some threads on this. You will have to search though.
   / Massey Ferguson 50 transmission question #3
Eight Gal is correct. I'm about to change my as soonas I find GL1 in 5gal pail
It has a dipstick on the side of the trans case
   / Massey Ferguson 50 transmission question #4
Danbo 56 You can get it at NAPA & it's the correct mineral gear oil & might be able to get it a TSC & that's a nice looking M-F 50 is it gasoline or diesel? this is a picture of my Mighty-Fine 50 1959. Item no. for NAPA GL-1 Mineral Gear oil is NHF 65205 online price $73.34
2018 New Holland C227 Compact Track Loader (A55315)
2018 New Holland...
2019 Dodge Charger Sedan (A55853)
2019 Dodge Charger...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
Swict 78" Quick Attach Bucket (A56469)
Swict 78" Quick...
White Metal Roof Panels (A55758)
White Metal Roof...
