Massey Ferguson 50 transmission question
   / Massey Ferguson 50 transmission question #1
yanmars
My brother has a MF50. His transmission is "stuck" in first gear, the hi-lo works but he cannot get it out of 1st into any other gear. He changed the transmission fluid he said about 1 year ago, the manual said 27 quarts so that is what he put in. He says the manual does not show a dip stick to check the level. That seems unusual to me but I do not have MF50.
Any thoughts on the transmission issue, he does not think it has external linkage to get in a bind and also the location of a dip stick. Thanks
   / Massey Ferguson 50 transmission question #2
The tractor is supposed to hold 8 gallons of 80w or 90w mineral oil. I believe there is a way to get it out of first. I believe you have to pull the fill plug and use a strong and lengthy screw driver to pry it. Try looking on yesterdays tractor forms, as they are more about tractors of the past. I do believe there are some threads on this. You will have to search though.
   / Massey Ferguson 50 transmission question #3
Eight Gal is correct. I'm about to change my as soonas I find GL1 in 5gal pail
It has a dipstick on the side of the trans case
   / Massey Ferguson 50 transmission question #4
Danbo 56 You can get it at NAPA & it's the correct mineral gear oil & might be able to get it a TSC & that's a nice looking M-F 50 is it gasoline or diesel? this is a picture of my Mighty-Fine 50 1959. Item no. for NAPA GL-1 Mineral Gear oil is NHF 65205 online price $73.34
2015 Ford Fusion S Sedan (A54815)
2015 Ford Fusion S...
Kubota 8" Excavator Bucket (A56469)
Kubota 8"...
golf cart (A55787)
golf cart (A55787)
2013 Kubota RTV-X900 Diesel Utility Cart (A55851)
2013 Kubota...
1999 CATERPILLAR CS-563D SMOOTH DRUM ROLLER (A52707)
1999 CATERPILLAR...
Bi-Parting Driveway Gate (A55853)
Bi-Parting...
