john deere 3320 hydro will not go in reverse error 14
   / john deere 3320 hydro will not go in reverse error 14 #1
Hank Simpson
sumner,washington
JD 3320
Can any one help with a reverse issue on a 3320 hydro error 14?
I have read a few forums with a few others with the same issue but know mentioned of what the repair was.
Currently I have checked voltage at the foot pedals both forward and reverse are the same 1 volt to 4 volts at full travel. I swapped the plugs at the pedals and the reverse pedal made the tractor go forward and the forward pedal caused the 014 error code. So I believe its either the trans controller ecm. or the solenoids. My problem I dont have the out put info, wiring schematic for the trans controller and I dont know where to find the forward reverse electric coils or actuators to swap or test.
Let me know if anyone has information on the e hydro
Thanks Hank
   / john deere 3320 hydro will not go in reverse error 14 #2
shoot me your email and I'll send you a PDF of the Deere Tech manual
Joe
Joe did you get my email I direct message you
Thanks Hank
Joe Thanks I found the coils under the fuel tank in a narrow hole on the bell housing.Tthe wires were chewed up by a critter on the reverse coil.
   / john deere 3320 hydro will not go in reverse error 14 #5
Glad ya found it!, whole lot cheaper than paying a dealer by the hours to hunt it!!!
   / john deere 3320 hydro will not go in reverse error 14 #6
and if you are lucky ... JD Tech will find a bad connector after 16 hours, Parts Plus 10.00 a hour!
Leo
   / john deere 3320 hydro will not go in reverse error 14 #8
Hank, I’m in the same situation as you were. We’re you able to access them without substantial dismantling and removing ? The fuel tank is in the fender on my 3320 tractor.
Thanks
Ted
   / john deere 3320 hydro will not go in reverse error 14 #9
Thanks
Ted
T/A Flatbed Trailer (A59231)
T/A Flatbed...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2017 Chevrolet Tahoe, 179,380 Miles, Decommissioned Law Enforcement Vehicle (A56438)
2017 Chevrolet...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
