Seized Honda GX 390
   / Seized Honda GX 390 #11
Pull the head (I think it is just 4 bolts), and that should remove all the mystery:) Can't hurt anything.
best,
ed
Is the piston going up and down as your turn the crankshaft ?
No clue- I was just turning from nut on assembly that recoil connects to. I guess I will pull the head in next day or so. I did do a You /tube search and came across a guy that bought "Sten" brand complete head assembly with valves for $105
   / Seized Honda GX 390 #13
Don't buy anything until you pull it, please let us know what you see.
Best,
ed
Yes-latest thing I did-pulled plug and confirmed-piston is functioning as it should.
   / Seized Honda GX 390 #16
OK then, it's time to disassemble the engine and see what the problem is. As someone else said, start with taking off the head and see what you see.
for sure-next step
   / Seized Honda GX 390 #18
Well guys an update. I pulled plug and shot some WD in it and then took recoil off and put a socket on crank. Should have done that first. Turned easy as can be-for bout 270 degrees. then I pulled valve cover. One rocker moving as it should while no movement on other-other then the rocker arm was very loose-no tension either way.
So lobe came off cam? valve broke and that is why wont go past 270? And I say 270-Plus or minus like 3/4 rottion and it jams???
Rotate the engine 2 full revolutions watching the valves before you pass judgement. The camshaft turns 1 revolution for 2 of the crank.
GC- only rotates about 270 degrees! then stops
   / Seized Honda GX 390 #20
My guess would be you have a broken rod.
Assortment of Pipes (A50121)
Assortment of...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2018 Ford Escape SE AWD SUV (A50324)
2018 Ford Escape...
2018 DODGE RAM 3500 (A52472)
2018 DODGE RAM...
2015 GMC Yukon XL Denali SUV (A50324)
2015 GMC Yukon XL...
2013 Ford F-150 Pickup Truck (A50323)
2013 Ford F-150...
