Bush hog keeps droping cant find leak
   / Bush hog keeps droping cant find leak #1
Allen bassin
Kubota 2003 b7500
Bush hog keeps dropping ggv down. I cant find a leak. 2003 b7500
   / Bush hog keeps droping cant find leak #3
This is what it looks like installed....top link omitted for picture:
   / Bush hog keeps droping cant find leak #4
You probably just need new seals on the lift cylinder for the 3 pt. It's located inside the rockshaft cover.
   / Bush hog keeps droping cant find leak #5
Look between your legs ( when your on the tractor) there is a knob, just close it and it well not drop.
   / Bush hog keeps droping cant find leak #6
That will fix it if it's a leaky valve. Not so much if it's leaky 3pt lift cylinders.
   / Bush hog keeps droping cant find leak #7
There is no charge per word here, so use enough of them to explain your issue.
While driving/mowing? While parked/stationary? Engine running or not? Over what duration? A few minutes? Hours? Overnight?
If you mean while running, are you using a tailwheel?
   / Bush hog keeps droping cant find leak #10
^^^^^100%
Can't help fix an issue with 10% of the info needed
2009 Ford F-650 24 ft Box Truck - 6.7L Cummins L6 Engine - Automatic Transmission - Low Mileage (A52748)
2009 Ford F-650 24...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2016 Chevrolet Traverse 1LT SUV (A50324)
2016 Chevrolet...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A52748)
2019 Energreen EVO...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
John Deere 1775 NT Exact Emerge 24 Row Corn Planter (A52349)
John Deere 1775 NT...
