Bush hog keeps droping cant find leak
   / Bush hog keeps droping cant find leak #1
Allen bassin
Kubota 2003 b7500
Bush hog keeps dropping ggv down. I cant find a leak. 2003 b7500
   / Bush hog keeps droping cant find leak #3
This is what it looks like installed....top link omitted for picture:
   / Bush hog keeps droping cant find leak #4
You probably just need new seals on the lift cylinder for the 3 pt. It's located inside the rockshaft cover.
   / Bush hog keeps droping cant find leak #5
Look between your legs ( when your on the tractor) there is a knob, just close it and it well not drop.
   / Bush hog keeps droping cant find leak #6
That will fix it if it's a leaky valve. Not so much if it's leaky 3pt lift cylinders.
   / Bush hog keeps droping cant find leak #7
There is no charge per word here, so use enough of them to explain your issue.
While driving/mowing? While parked/stationary? Engine running or not? Over what duration? A few minutes? Hours? Overnight?
If you mean while running, are you using a tailwheel?
   / Bush hog keeps droping cant find leak #10
^^^^^100%
Can't help fix an issue with 10% of the info needed
2021 VemaTEC 30in Excavator Bucket (A51691)
2021 VemaTEC 30in...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2015 Peterbilt 320 Truck (A51692)
2015 Peterbilt 320...
2016 FORD F450 CREW CAB SERVICE TRUCK (A52576)
2016 FORD F450...
2013 Nissan Juke SUV (A50324)
2013 Nissan Juke...
2009 HINO 185 18FT BOX TRUCK (A52577)
2009 HINO 185 18FT...
