Bush hog keeps droping cant find leak
   / Bush hog keeps droping cant find leak #1
Allen bassin
Kubota 2003 b7500
Bush hog keeps dropping ggv down. I cant find a leak. 2003 b7500
   / Bush hog keeps droping cant find leak #3
This is what it looks like installed....top link omitted for picture:
   / Bush hog keeps droping cant find leak #4
You probably just need new seals on the lift cylinder for the 3 pt. It's located inside the rockshaft cover.
   / Bush hog keeps droping cant find leak #5
Look between your legs ( when your on the tractor) there is a knob, just close it and it well not drop.
   / Bush hog keeps droping cant find leak #6
That will fix it if it's a leaky valve. Not so much if it's leaky 3pt lift cylinders.
   / Bush hog keeps droping cant find leak #7
There is no charge per word here, so use enough of them to explain your issue.
While driving/mowing? While parked/stationary? Engine running or not? Over what duration? A few minutes? Hours? Overnight?
If you mean while running, are you using a tailwheel?
   / Bush hog keeps droping cant find leak #10
^^^^^100%
Can't help fix an issue with 10% of the info needed
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
Oliver & Dahlman 6' Grapple (A50121)
Oliver & Dahlman...
Club Car Electric Utility Cart (A51694)
Club Car Electric...
2018 Kubota L4701 (A50120)
2018 Kubota L4701...
2012 FORD F-650 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2012 FORD F-650...
