Bush hog keeps droping cant find leak
   / Bush hog keeps droping cant find leak #1
Allen bassin
Kubota 2003 b7500
Bush hog keeps dropping ggv down. I cant find a leak. 2003 b7500
   / Bush hog keeps droping cant find leak #3
This is what it looks like installed....top link omitted for picture:
   / Bush hog keeps droping cant find leak #4
You probably just need new seals on the lift cylinder for the 3 pt. It's located inside the rockshaft cover.
   / Bush hog keeps droping cant find leak #5
Look between your legs ( when your on the tractor) there is a knob, just close it and it well not drop.
   / Bush hog keeps droping cant find leak #6
That will fix it if it's a leaky valve. Not so much if it's leaky 3pt lift cylinders.
   / Bush hog keeps droping cant find leak #7
There is no charge per word here, so use enough of them to explain your issue.
While driving/mowing? While parked/stationary? Engine running or not? Over what duration? A few minutes? Hours? Overnight?
If you mean while running, are you using a tailwheel?
   / Bush hog keeps droping cant find leak #10
^^^^^100%
Can't help fix an issue with 10% of the info needed
2017 POLARIS RANGER 500 EFI UTV (A51247)
2017 POLARIS...
2018 FORD TRANSIT T250 CARGO VAN (A52577)
2018 FORD TRANSIT...
2016 Ford Fusion Hybrid Sedan (A50324)
2016 Ford Fusion...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
