Kubota 2650
   / Kubota 2650
Thank you all for this info an pictures... i have already dealt with the peddle issue and replaced all worn parts two months ago. Im positive it is not that....this time.
   / Kubota 2650 #12
Check/bypass/jumper the various safety switches that affect the starter, there would be 2-4 of them. Off the top of my head (not specific to 2650): PTO, seat, treadle. No clutch pedal on 2650, correct? Otherwise add that one to the list and skip the seat (Kubota HST models with clutch pedal can let you start without occupant in the seat as long as clutch depressed).
   / Kubota 2650
10-4 checking all those no luck yet
   / Kubota 2650 #14
I agree with CoyPatton. You might start with the starter first. I may have missed it, but if you remove the 12v from the starter selnoid, do you find 12v when you key the starter. If not, then it may be safety switches or ignition switch. It may be a bad starter or sel. But, I would guess you thought of that and already checked the voltage to the starter. Best Wishes.
   / Kubota 2650 #15
Just throwing this out there because I've been burned twice on this. On two occasions over the last 5 years I've had a similar issue. Starter won't engage, click, or do anything, but I've got lights and gauges. Turns out I had a bad ground from frame to battery both times. Ground was good enough for small things, but not good enough to engage the starter. I'm sure you've already thought about this, but just in case.......
   / Kubota 2650 #16
Hi folks..gravelman My 2650 will not start..actually the starter will not engage. Been working fine all am, went to crank , nothing...checked as many connections as i could or know of...no fuses blown. juice to everything else on machine. Any ideas out there??? thanks much have to call road service i guess..
Do you hear it click when you attempt to start it? I had that problem on my John Deere 2240 and found that the Key Switch was the problem. The tractor is a 1980 model with original key switch.
   / Kubota 2650 #17
That^
Hearing the fuel pump spin up with the key? I'd check continuity real quick on the starter ground to the battery then start working backward from there through all the safeties.
   / Kubota 2650 #18
I had a mouse chew the pto safety switch wires
   / Kubota 2650 #19
Exactly why I say check with a multi-meter. May look good at both ends but somewhere in the middle those little bastards…
   / Kubota 2650
Thank you all... good stuff. I found the safety switch for the hst peddle had loosened up and was not in alighment with the hardware that activates it... so close but not detected till i got help watching things move. There are two nuts under there that are hard to tighten because access is so damn difficult.
2018 Ford Escape SUV (A50324)
2018 Ford Escape...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A52748)
2022 Quick Attach...
2008 Jeep Patriot Sport SUV (A50324)
2008 Jeep Patriot...
2008 Volkswagen Eos Convertible (A50324)
2008 Volkswagen...
2008 Ford Taurus X SUV (A50324)
2008 Ford Taurus X...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
