Ford 9N intermittent spark, won't run
   / Ford 9N intermittent spark, won't run #1
JRP3
Member
Iseki TL-2101FD
6 Volt positive ground system, parked it about a month ago, now it will only fire for a second if at all. Put a clamp on timing light on the plug wires and only occasionally get a flash when cranking. Put a test light between the coil and ground, it lights when the ignition is on and flashes when cranking, so I'm assuming the points are working. Volt meter between the coil and battery ground shows voltage fluctuating when cranking between full battery voltage and about 2.5V. Coil is about 3 years old, tractor hasn't seen much use. Sanded the rotor, cap, and points even though they didn't look bad. Haven't tried hot wiring from the battery to the coil yet but I guess that's the next step. Any other ideas?
What readings should I get?
So when I was reading the coil voltage while cranking and it dipped to 2.5V that was too low, or is it not accurate while cranking it?
   / Ford 9N intermittent spark, won't run #6
I'd call it low. It should fluctuate between 6 and 4.5 while she points open and close, dependent on voltage drop caused by the starter's current draw.
   / Ford 9N intermittent spark, won't run #7
Clean your battery terminals well, as well as the connectors that attach to them. Tighten securely. Follow the ground to the frame and be sure it's clean and tight. Any voltage drop at any of these points is too much voltage drop. If it still won't run check the point gap and the timing. Do you have any moisture or cracks in the distributor cap? Are you sure the rotor makes good contact with the center of the cap? Are you sure your condenser is good? Be sure the points are tightened down securely.
   / Ford 9N intermittent spark, won't run #8
Jumper around your key switch, that has always been a weak part of the ignition system.
   / Ford 9N intermittent spark, won't run #9
CONDENSER
   / Ford 9N intermittent spark, won't run #10
As the previous poster said… Condenser.
Disconnect it and see if you get spark.
1978 ASPT 30ft Pole S/A Towable Trailer (A48081)
1978 ASPT 30ft...
2021 Delta Redirective Crash Cushion 75000 (A48081)
2021 Delta...
Kubota M4700 4WD Tractor (A50860)
Kubota M4700 4WD...
2012 Ford F-350 Omaha Crane Service Truck (A48081)
2012 Ford F-350...
2016 Kia Cadenza Sedan (A48082)
2016 Kia Cadenza...
2024 Bintelli ActivEV Pulse Electric Golf Cart (A48082)
2024 Bintelli...
