ZD1511 blowing white smoke on a hillside at times : Help
   / ZD1511 blowing white smoke on a hillside at times : Help #1
Brown Dog
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
Engine has blew excessive white smoke out exhaust 4 different times 5-10 seconds while mowing crossways on a hillside / bank with left side of deck downhill.
ZD1511 has around 170hrs on it.
I bought it new.
I can’t duplicate this concern.
it wasn’t in regen when this happened & runs fine.
it smells like engine oil smoke but crankcase isn’t over-filled.
Anybody else experienced this ?
   / ZD1511 blowing white smoke on a hillside at times : Help #2
White smoke usually means one of a few things...a new pope is one...! another is water in the fuel...it could be coming from a separator etc. when the angle is right...
I kindly doubt it’s water in fuel.
I run 3 tractors from same 550gal tank with no issues at all.
im just unsure at this point
   / ZD1511 blowing white smoke on a hillside at times : Help #4
What’s your fuel level? This happens on my ZD 331 when it’s low of fuel. It’s getting air in the system
Fuel level would be 1/2 to 3/4 full in both tanks.
the last time this happened during the smoking I heard a light clattering from engine : like valve clatter or spark knock in a gas burner from poor fuel.
Engine rpm also dropped ….. idk weird.
   / ZD1511 blowing white smoke on a hillside at times : Help #6
I bought it new.
When it's tilted too much it is overfilled on the lowside. When engine oil is too deep it burns it off. It will do it in trucks too. Typical.
This is what I suspected too.
crankcase isn't overfilled.
Thanks guys (y)
Well IF my ZD511 isn’t making oil (from DPF Tier4 BS) I DID overfill it with engine oil.
book says 6.8qts
It’s was 3/4” over the full mark although I’ve Checked it numerous times since I changed it back in the spring.
I drained both oil plugs, did not remove filter & poured 4.6qts in & it’s on full mark.
Little oil filter won’t hold 2.2qts so I’m thinking operators manual is wrong …. As my KTM 950SE AND F350 6.7L was also wrong
strait out of my operators manual
I’m thinking no more than 4.8qts with filter change 🤷‍♂️
2003 CATERPILLAR 420D BACKHOE (A51242)
2003 CATERPILLAR...
(INOP) CASE IH MAGNUM 180 TRACTOR (A50459)
(INOP) CASE IH...
2021 Case Trident 5550 Spreader (A51039)
2021 Case Trident...
JOHN DEERE 975 3 BOTTOM SWITCH PLOW (A51243)
JOHN DEERE 975 3...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
TOYOTA 8FGCU30 FORKLIFT (A50854)
TOYOTA 8FGCU30...
