Truck Repair In Pakistan (I think, I can't read Arabic)
   / Truck Repair In Pakistan (I think, I can't read Arabic) #11
Have you seen the size loads they put on their trucks? They need that many springs.
Yes, eyeballing i guess they arent shy loading 60 ton on a three axle truck.... these guys allways have work, beefing up chassis, then stacking more leafs, then welding new axle tubes to broken axles... its a never ending cycle on Pakistani Truck Channel...
   / Truck Repair In Pakistan (I think, I can't read Arabic) #12
Another major factor is wear and tear.
Roads in that area are mountainous and TERRIBLE!
That how they trim their toenails, with welding slag.o_O On the one with them riveting the frame together there was a guy holding a rivet drift with his bare hands and the other guy swinging sledge hammer with all his might.:eek: When I nod my head you hit it.🤔🍻
I've seen that in a few of their videos. The guy with the hammer must have a good aim, because I haven't seen one of them missing a finger or cast on their hands.
I'll have to find the link to the video, but it showed a brand new two axle truck chassis that they completely disassembled, right down to the bare individual frame rails. All the rivets had the heads chiseled off with a chisel and a sledge hammer, then punched out with the same. Video title said they were going to "strenghthen" it.
Link:
   / Truck Repair In Pakistan (I think, I can't read Arabic) #14
The guys with the casts or missing fingers are fired immedatily. 🍻
   / Truck Repair In Pakistan (I think, I can't read Arabic) #16
You don't have to go as far away as Pakistan to see similar type repair.
90 miles away......in Cuba also!
Do they load 50 ton on a 3 axle truck in Cuba as well ?
   / Truck Repair In Pakistan (I think, I can't read Arabic) #17
No, I don't think so, but they make parts, or jury rig most everything.
I watched a couple videos of them fixing broken rear axle housings, usually broken in the inner spindle area. They usually cut it off and welded on a new spindle, and they sometimes added a strap on the bottom of the housing to reinforce it. They even have a jig like a mill divider head set up so they can chuck the good spindle in a three jaw chuck and rotate it as they weld and cut on it. They also have a large lathe they can put a whole housing in and rotate it if needed.
   / Truck Repair In Pakistan (I think, I can't read Arabic) #19
There’s videos of China trucks running a lot heavier than that.
   / Truck Repair In Pakistan (I think, I can't read Arabic) #20
It might be me but I thought I saw a Jasper sign on the head rebuilding video.:giggle:🍻
2022 TAKEUCHI TL12R2 SKID STEER (A51246)
2022 TAKEUCHI...
2020 JOHN DEERE 7R210 LOT IDENTIFIER 47 (A53084)
2020 JOHN DEERE...
2023 Bobcat E32i Mini Excavator (A51573)
2023 Bobcat E32i...
JCB 507-42 Telehandler (A51573)
JCB 507-42...
(2) 24" W X 5 1/2L HEAVY DUTY FOLD UP TRAILER RAMP (A51247)
(2) 24" W X 5 1/2L...
