Has anyone had any experience with "swinging lawn mower blades"?
   / Has anyone had any experience with "swinging lawn mower blades"? #1
Navvet
NC
Mahindra 4025 Bobcat S185 John Deere X495 John Deere 6x4 Gator
Ran across the Meg-Mo Rotary Mulching Blades as well as the Cutlass blades for a lawn mower. Looks like a bush hog type blade for a lawn mower.
Just wondering if they would be worthwhile on a JD Diesel with a 62" deck.
   / Has anyone had any experience with "swinging lawn mower blades"? #2
I just adapted some flat disk mower blades to a walk behind string trimmer. They worked great. I don't see why they wouldn't work good for any mower. I plan to expand on using them in the future.
   / Has anyone had any experience with "swinging lawn mower blades"? #3
Great looking project, inspires me to make one up for my Ariens 6hp 22". I have an alum round to make a hub from and plenty of 10" saw blades that are too far gone to sharpen again.
My .155" lines are looped/doubled into the head, but encountering woody stems <3/8" tends to snag and pull 'em out. Looks like two swinging blades might be enough to do the job. btw, thanks for the great video and demo. (y)
   / Has anyone had any experience with "swinging lawn mower blades"? #4
Almost could use a stump jumper type hub to assist in keeping the blades out of the dirt.
   / Has anyone had any experience with "swinging lawn mower blades"? #6
Hard to tell in the vid, but how did your RPM do? I have an old DR version (wire wheels one) that slows way down if I use .155 longer than 10" per side.
   / Has anyone had any experience with "swinging lawn mower blades"? #7
I have been using Meg-Mo blades on my 60 inch finish mower. I prefer them over standard mower blades.
   / Has anyone had any experience with "swinging lawn mower blades"? #8
Very little variation. I haven't ever checked but the 6 hp briggs on my Craftsman sounds like it runs slower than the typical 3600 rpms. This blade setup mows right at the dirt level.
I don't think mine ever bogged with full length strings.
If you don't mind, How are they for durability ? I mow several acres with my 62" deck and I tend to be a bit rough on blades.
Thanks
   / Has anyone had any experience with "swinging lawn mower blades"? #10
I would like to try Meg-Mo blades, but the $310 cost for my 60" deck is too steep. They claim they last 8X longer than normal blades. I get a set of Oregon Gator blades for $40 online, X 8 is $320. No advantage cost wise.
2017 Ford Transit 250 Cargo Van (A59230)
2017 Ford Transit...
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
2018 Kubota RTV500 4x4 Diesel Utility Cart (A59228)
2018 Kubota RTV500...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
2006 CATERPILLAR 304C (A58214)
2006 CATERPILLAR...
2016 KENWORTH T680 TANDEM AXLE DAY CAB (A59905)
2016 KENWORTH T680...
