Rear blade for snow on gravel, pipe or rubber mat?
   / Rear blade for snow on gravel, pipe or rubber mat? #21
An interesting theory, but not workable on most driveways around here. Especially the section of mine with 14% slope that faces north. After a couple of passes with a vehicle it becomes a sheet of ice that provides a very quick trip to the bottom of the hill, and you can't scrape it off until it melts in its own sweet time.
If I had that problem, I would either paved it so I could scrape it, or bring in a mix of sand and salt and rig up a spreader.
   / Rear blade for snow on gravel, pipe or rubber mat? #22
Whats the avg snow in Boone?
I have no idea. It varies widely from year to year, from an inch or two to over 20 inches. Some years I never plow, and once in a while my rear blade can't handle it and I end up "shoveling" it with the FEL. Last time it did that it took be two days (admittedly not 8-hour days) to clear it.
No matter what the average is, in a year that we get six to 10 inches and it stays cold we can't get home if we let it turn to ice. Last year we were homebound most of a week because we guessed it would get warm and melt, so drove on it, and it didn't.
   / Rear blade for snow on gravel, pipe or rubber mat? #23
I've thought about paving, but it's a quarter mile long so that's a lot of money. And most of the time enough of the gravel sticks up through what's left on the road to provide traction. I'd think if it were paved it would have to be kept clean or the ice issue would be worse.
I'm told by local road builders that putting salt on a gravel drive is a big no-no. They tell me it causes the top layer to stay unfrozen, over a frozen base, so it becomes undrivable, so the only solution is to remove the salted soil and rebuild the entire road. I've not tested that so don't know from personal experience.
   / Rear blade for snow on gravel, pipe or rubber mat? #24
It becomes a question of - do I really need to plow or just drive thru it. I have a mile long gravel driveway. Straight as an arrow with one valley. Last three years I've just driven thru it and let it melt down.
If I MUST plow and the driveway is still soft - reverse the blade 180 degrees and clear the snow that way. I have a VERY heavy Rhino rear blade and it works well reversed.
   / Rear blade for snow on gravel, pipe or rubber mat? #25
Straight salt is not good for them as it will thaw the gravel/dirt and become sloppy and slick on top.
Sand with just enough salt mixed in to keep the freezing in the pile limited so you can dig it out does a good job.
Sander is mounted on a trailer now,
When it was truck mounted, it is also handy for spreading ashes on the driveway to save sand and use the ashes (I burn coal for supplemental heat)
I have to sand my driveway as most of it is 14-16 degrees or about 25% slope and much of it is shaded,
any wheel traffic on turns the snow into ice and then it's a bob sled run with an S turn in it.
Not real nice in a vehicle.
Had to edit this post the pictures ended up as invalid attachments????
   / Rear blade for snow on gravel, pipe or rubber mat? #26
The snow plow operators worst nightmare:
Heavy wet snow on unfrozen gravel or dirt road!
OR
24 inch event when your plow is 16 inches high
ADD
every drive is uphill
   / Rear blade for snow on gravel, pipe or rubber mat? #27
Have some adjustable skid shoes fabricated like on truck snow blades. Make brackets and use skids already available. No matter what you use you'll still get some loose gravel moved.
   / Rear blade for snow on gravel, pipe or rubber mat? #28
Turning the blade backwards when the gravel wasn’t froze worked pretty well for me until last year when I finally spent the money for a new tractor and snowblower.
The adjustable shoes they sell for plow trucks and ATV’s work pretty well but I never attempted mounting them on my rear 3 point blade.
   / Rear blade for snow on gravel, pipe or rubber mat? #29
Our drive is irregular in angle and surface. Keeping it in shape is a challenge not much helped by wintertime plowing.
I like the idea of putting a pipe onto the cutting edge of the back blade. It might work on the FEL as well.
Wondering about how to attach it, and also wondering if there is some sort of heavy two two inch rubber hose that would work. Maybe a used fire engine hose?
Has anyone tried that?
rScotty
   / Rear blade for snow on gravel, pipe or rubber mat? #30
I made shoes for my 7' rear blade to prevent dig-in. Like other's said, most times I just run the blade backwards.
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
2012 Ford F-450 Altec AT200A 30ft Bucket Truck (A55852)
2012 Ford F-450...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
2017 JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
2017 JOHN DEERE...
