Emax 22 RPM gauge inop
   / Emax 22 RPM gauge inop #1
mcleod9
Mahindra emax 22s
My rpm gauge stopped working. All the other gauges work fine. Any ideas? I'm trying to figure out how to get the dash off to check the gauge wiring.
   / Emax 22 RPM gauge inop #2
Mine did the same thing. Try squeezing the orange wire connection to the alternator. My dealer said this is a relatively common problem, and it usually turns out to just be the loose wire. It fixed my problem.
   / Emax 22 RPM gauge inop #3
This is the connection that was loose on mine.
No luck. I even seperated the wire connection you showed. Everything was good there. I broke down and removed the steering wheel and the instrument console. No sign off any damage to the wiring harness. I unplugged the two connectors on the rear of the panel, sprayed both with contact cleaner. Didn't help. I'm thinking the gauge itself may be bad. Only 55 hours seems a little fast, though. thanks
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A52384)
2007 INTERNATIONAL...
90018 (A48082)
90018 (A48082)
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51691)
2006 iDrive...
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
2007 STERLING T/A DUMP TRUCK (A51406)
2007 STERLING T/A...
