Emax 22 RPM gauge inop
   / Emax 22 RPM gauge inop #1
mcleod9
Mahindra emax 22s
My rpm gauge stopped working. All the other gauges work fine. Any ideas? I'm trying to figure out how to get the dash off to check the gauge wiring.
   / Emax 22 RPM gauge inop #2
Mine did the same thing. Try squeezing the orange wire connection to the alternator. My dealer said this is a relatively common problem, and it usually turns out to just be the loose wire. It fixed my problem.
   / Emax 22 RPM gauge inop #3
This is the connection that was loose on mine.
No luck. I even seperated the wire connection you showed. Everything was good there. I broke down and removed the steering wheel and the instrument console. No sign off any damage to the wiring harness. I unplugged the two connectors on the rear of the panel, sprayed both with contact cleaner. Didn't help. I'm thinking the gauge itself may be bad. Only 55 hours seems a little fast, though. thanks
2014 Chevrolet Tahoe 4x4 SUV (A52377)
2014 Chevrolet...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
1994 FMD S/A Towable Sprayer (A51691)
1994 FMD S/A...
1779 (A51248)
1779 (A51248)
2013 Nissan Pathfinder SUV (A51694)
2013 Nissan...
2019 FORD F-550 SERVICE TRUCK (A53843)
2019 FORD F-550...
