Emax 22 RPM gauge inop
   / Emax 22 RPM gauge inop #1
mcleod9
Mahindra emax 22s
My rpm gauge stopped working. All the other gauges work fine. Any ideas? I'm trying to figure out how to get the dash off to check the gauge wiring.
   / Emax 22 RPM gauge inop #2
Mine did the same thing. Try squeezing the orange wire connection to the alternator. My dealer said this is a relatively common problem, and it usually turns out to just be the loose wire. It fixed my problem.
   / Emax 22 RPM gauge inop #3
This is the connection that was loose on mine.
No luck. I even seperated the wire connection you showed. Everything was good there. I broke down and removed the steering wheel and the instrument console. No sign off any damage to the wiring harness. I unplugged the two connectors on the rear of the panel, sprayed both with contact cleaner. Didn't help. I'm thinking the gauge itself may be bad. Only 55 hours seems a little fast, though. thanks
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2018 JLG 3246ES 32ft Electric Scissor Lift (A51691)
2018 JLG 3246ES...
2025 IR UNUSED Cleanout Bucket (A53117)
2025 IR UNUSED...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
