Can't get a Kubota M5-111 so, what now?
   / Can't get a Kubota M5-111 so, what now? #1
Sid Post
TX and OK
Massey 5711D, Kubota L4600, Kubota B2601
I finally have the money to buy my tractor but, it has gone up $8K and does NOT INCLUDE an 11% steel premium from Kubota. I apparently can't order until Feb/March of next year and the earliest delivery date would be Jan 2023! The price today if I could order would be $72K plus 11% for the steel premium.
How does a New Holland Powerstar 110 with Loader at $65.5K compare? Or, a John Deere 6105E with a loader at $84K?
I need and want a stout loader with a heavy-duty bucket with Skid Steer mounting strongly preferred so I don't have to rebuy attachments though, the pallet forks are really the only one I would need to replace ASAP.
The tractor needs to be a good round bale tractor for both the baler and the loader for stacking bales. The loader will also see a good deal of pallet work with pallet loads of concrete and general steel movement.
I'm having a hard time seeing an additional ~$20K in the John Deere over the New Holland. I'm not hard set against Massey, Case-IH, or others but dealer support locally would be non-existent. The New Holland is on the lot today. The John Deere would deliver in October (of the 20 tractors in-bound, 10 are sold as of today).
What have I overlooked? What words of wisdom do the RKI (reasonably knowledgable individuals) have?
TIA,
Sid
   / Can't get a Kubota M5-111 so, what now? #2
Given your location I expect your round bales are 5x6. Is this accurate and how many bales will you be baking with your new tractor?
   / Can't get a Kubota M5-111 so, what now? #4
TIA,
Sid
Sid,
I am also a hay farmer. I have a large frame Case IH, a mid frame Massey and 2 Kubotas. I don’t think you can really go wrong with any of the big legacy name brands. I have found that CNH tractors (Case-IH or NH) or AGCO (Massey Ferguson or Fendt) are specifically made for farming. I would encourage you to lean in their direction. I generally believe that Deere is as well, but is not worth the 20% premium. The only tractor worth the premium money is Fendt.
Theres no way in heck I’d wait that long for a Kubota if a CNH or AGCO brands were ready to be delivered. New Holland and Case-IH are the same tractors with different paint now. Both are owned by FIAT, which kinda sucks, but welcome to the “new norm”.
If I were you, I’d be looking at an older Case-IH Maxxum with a 5.9L Cummins and no exhaust after treatment BS. You’ll pay less than 1/2 the price of a new tractor and you can work on it yourself with simple tools.
I have a Case-IH MX270 Magnum with an 8.3L Cummins and could not be happier.
   / Can't get a Kubota M5-111 so, what now? #5
Another suggestion: I have a 2008 Massey Ferguson 7495. It has all the creature comforts a man could want, no exhaust treatment systems, but most importantly, it has a CVT transmission which is the greatest gift ever given to the farm tractor since the PTO. They make smaller versions with CVT transmissions.
I heartily suggest you look at those units, too.
   / Can't get a Kubota M5-111 so, what now? #6
Personally, I'd be looking hard at a Massey of that size farm tractor, these days they seem to be the most farm tractor for the least money, and folks seem to be very happy with them.
The ones I personally would stay away from, are the New Hollands...
The problem with deere is, they want too much $ for green paint!!
SR
   / Can't get a Kubota M5-111 so, what now? #7
A $20K premium for an E series Deere is absurd. I'm waiting on more info from the OP about his round baling needs. I'm not sure ~110 engine hp is enough and I'm not sure the chassis he is considering are robust enough to handle the pallets he is describing.
It really depends on rainfall and other weather factors. The nominal volume is probably around 100/year but, can be as few as 60 or occasionally a lot more if the weather is good.
What about the 5 series? 5100 or 5115?
I think I want more tractor weight in the frame and major drive components for a better longterm ownership experience. Loader work with heavy bales up high or a baler in bad field conditions can really beat on a smaller tractor.
That's the main reason I ruled out an M4. Sure, the extra PTO HP is nice but, I can live with a little less width on a mower or run a little slower ground speed with the baler but, I can't do anything with stability stacking bales three high or onto a trailer or when the baler is trying to "steer" the tractor in the field.
There are also odd jobs to keep in mind like a pallet of concrete or moving a steel object. ~3400lbs (concrete pallet weight) will unbalance a lot of tractors which is a safety issue I want to avoid. That also doesn't factor in the financial loss if no one is hurt when the tractor rolls or tips over.
Sid,
I am also a hay farmer. I have a Case IH a Massey and 2 large Kubotas. I don’t think you can really go wrong with any of the big legacy name brands. I have found that CNH tractors (Case-IH or NH) or AGCO (Massey Ferguson or Fendt) are specifically made for farming. I would encourage you to lean in their direction. I generally believe that Deere is as well, but is not worth the 20% premium. The only tractor worth the premium money is Fendt.
The German John Deere and Fendt options are certainly awesome tractors. If I was into precision agriculture, I could see one of those being a good investment. The reality though is the price tag is so high I can't see one on my property anytime soon and, the added features and functionality aren't something I can really use or take advantage of much, if at all.
Case-IH around here isn't supported in any meaningful way. New Holland isn't exactly a brand with a wide array of dealer support options but, there is a strong dealer about ~30 miles away. However, if they go under which is a possibility in today's economy, I have a really long drive for parts or service. Fiat has a bad reputation but, like Ferrari and Ducati, the Italians can make good reliable products at a price the market will accept. New Holland tractors I have been around always seemed functional but, a little basic overall. Sort of a John Deere economy tractor experience if you will.
The Case-IH Maxxum options sound like something worth looking into though, I probably would be looking at shipping one in from out of state.
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
2015 Chevrolet Tahoe, 192,897 Miles, Decommissioned Law Enforcement Vehicle (A56438)
2015 Chevrolet...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
