Midniteoyl
Elite Member
- Joined
- May 20, 2013
- Messages
- 4,773
- Location
- N. W. Indiana
- Tractor
- Kioti CK3510SE HST, Ford 3400, Gizmow ZTR, Simplicity 7016H
I think you've got the answer but I can't quite understand how it works on my lift. You're saying that on your tractor that small cylinder above the boom cylinder has its input and output connected to the curl cylinder, so when the boom cylinder raises, the small cylinder is extended and forces fluid into the curl cylinder to extend in just the right proportion to keep the bucket level. That makes sense.
So when I look at my lift, there are 3 cylinders involved, I'll call them the upper arm lift cylinder, lower arm lift cylinder and cage leveling cylinder. If either of those lift arm cylinders moves, it causes the basket to go out of level unless the leveling cylinder moves the right amount in the right direction. So how are both lift arm cylinders "connected" to the leveling cylinder and what does it mean to be connected. It almost seems like I need one more cylinder to mimic the behavior of your tractor.
See if this is more like what you have:
How to Easily Design a Hydraulic Leveling System | Mentored Engineer
There are many times in my design career that I needed to translate an object without rotating. Lifting an object on a table is a…
>The traditional use is for platform leveling on a man lift. At the platform, there would be an upper hydraulic cylinder between the platform and the boom. This cylinder is driven by a similar lower cylinder between the boom and the riser or knuckle. It is important to note that the lower cylinder does not raise and lower the boom, it is there to tell the upper cylinder what to do.
