Suddenly increasing leak around hydraulic filter
   / Suddenly increasing leak around hydraulic filter
Okay - so... no idea why it suddenly started leaking. Replaced filter the typical way, no leaks, no drips, no problems. Weird, but ok.
   / Suddenly increasing leak around hydraulic filter #12
Did you look closely at the old gasket? If it's not abraded or torn, the only thing I can think of is there was a piece of crud under the gasket and when you removed the old filter it got cleaned off. It would be interesting to cut that filter open and see if the filter element was clogged. If so, the pressure could have been rising enough to open the bypass and that was enough pressure to force some oil out around the gasket.
UNUSED Tool Set (A53117)
UNUSED Tool Set...
378102 (A54865)
378102 (A54865)
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2015 INTERNATIONAL LF687 (A53843)
2015 INTERNATIONAL...
EZGO (A50324)
EZGO (A50324)
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
