Suddenly increasing leak around hydraulic filter
   / Suddenly increasing leak around hydraulic filter
Okay - so... no idea why it suddenly started leaking. Replaced filter the typical way, no leaks, no drips, no problems. Weird, but ok.
   / Suddenly increasing leak around hydraulic filter #12
Did you look closely at the old gasket? If it's not abraded or torn, the only thing I can think of is there was a piece of crud under the gasket and when you removed the old filter it got cleaned off. It would be interesting to cut that filter open and see if the filter element was clogged. If so, the pressure could have been rising enough to open the bypass and that was enough pressure to force some oil out around the gasket.
2000 Ford F-650 Truck, VIN # 3FDNF6541YMA65799 (A54865)
2000 Ford F-650...
2015 Nissan Altima Sedan (A54815)
2015 Nissan Altima...
White Metal Roof Panels (A53425)
White Metal Roof...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
Case 1083 20ft Corn Head (A55302)
Case 1083 20ft...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
