Suddenly increasing leak around hydraulic filter
   / Suddenly increasing leak around hydraulic filter
Okay - so... no idea why it suddenly started leaking. Replaced filter the typical way, no leaks, no drips, no problems. Weird, but ok.
   / Suddenly increasing leak around hydraulic filter #12
Did you look closely at the old gasket? If it's not abraded or torn, the only thing I can think of is there was a piece of crud under the gasket and when you removed the old filter it got cleaned off. It would be interesting to cut that filter open and see if the filter element was clogged. If so, the pressure could have been rising enough to open the bypass and that was enough pressure to force some oil out around the gasket.
2014 Chevrolet Tahoe SUV (A55853)
2014 Chevrolet...
2015 Freedom Trailers 6X10A 10ft Enclosed Cargo Trailer (A55758)
2015 Freedom...
Etnyre 2000 Gal Asphalt Dist. Truck (A47477)
Etnyre 2000 Gal...
MILLERMATIC 252 W/LEADS (A55745)
MILLERMATIC 252...
2013 BMW X5 xDrive35i AWD SUV (A55758)
2013 BMW X5...
2004 Honda Civic Coupe (A55758)
2004 Honda Civic...
