etpm
- Joined
- Jun 30, 2021
- Messages
- 2,325
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
Well, your buddy is kinda right. If you were stick welding you would end up putting in less total heat to the parts than if brazing. And if it was mild steel you were joining then stick welding would be a good choice.So on another note, I ran into one of the machinists from the shop around the corner today at the hardware store. Actually the first dude I showed it to asking for advice a couple weeks ago when I started analyzing what the heck I'm gonna do about this.
Told him I was thinking of brazing it with bronze instead of stick welding it with nickel cuz I'm worried 5/8" thick of weld bead by 8" long would generate way too much heat and warp the thing. He said it's the other way around, because for the bronze to flow and stick well the whole vicinity of the patch has to be heated red hot if not orange.
Sooo, what's correct? Conventional wisdom is that brazing doesn't require heating the base metal as much as welding. I think my machinist friend's viewpoint is incorrect cuz we all know that under that welding stick the metal is white hot. And, for what it's worth, when I stick welded a stabilizer foot that had broken in half the other day it twisted and warped all over the place. That didn't bother me cuz the foot isn't a precision piece. But the hub is.
I think my machinist buddy is like an "on the job training" kinda guy who specializes more in cutting metal with lathes and mills rather than weird types of welding. I know he's a wizard in other aspects so don't want to discard what he says but I'm hoping he's wrong here.
What do y'alls think?
Cast iron though is not as near as ductile as mild steel. It will get very hot in the heat affected zone when welded. And the heat affected zone is small, just as the machinist said. So the cast iron gets real hot in a small area which causes it to expand. Then when it cools it shrinks. But since it is not very ductile the cast iron cannot move. So it cracks.
The remedy to the cracking problem is heating a large area, in your case the whole part. Then upon cooling the shrinking happens over a large area and so there is less relative movement and the part doesn't crack. There are welding rods for stick welding cast iron that tend to cause less cracking. Castweld 55, made by Stoody, is one rod. But for a piece as thick as yours I guarantee your part will crack unless pre-heated if stick welded with Castweld 55. But you are gonna be gas welding anyway.
Since it seems like you are getting the hang of brazing and you can obviously get a good braze then I wouldn't be concerned. However, you need to practice on a hot part the same approximate thickness as your broken part before you attempt to braze the real thing.
And your machinist friend needs to read up on weld and braze repairing cast iron.
Good Luck,
Eric
